03-19-2019, 20:16 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | SM-J120W baseband unknown anyway to repair? [Answered] just i am asking if i can repair this phone no imei baseband uknown |
03-20-2019, 04:35 | #2 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | point de vue yes can repair reset efs bro make sure u can find a imei for fix and but imei cpid. or patch imei if possible with this model u can try to use modem combination file too if can find it free. |
The Following User Says Thank You to ghacks For This Useful Post: |
03-20-2019, 08:54 | #3 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
You can download combiantation firmware for this device from the Support Area. | |
03-20-2019, 17:40 | #4 (permalink) |
Junior Member Join Date: Apr 2016 Location: haiti
Member: 2554183 Status: Offline Thanks Meter: 1 | Please can you be more explicit. I download. Which section should I check for flash cause I already crash my baseband. J120az Sent from my iPhone using Tapatalk |
03-21-2019, 09:04 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You can download combination firmware for this device from the Support Area. To enter Support Area, press "Go to support" button on "Support & options" tab of the Software, check for /samsung/COMBINATION/ folder. Last edited by Octopus support; 03-22-2019 at 07:42. |
03-22-2019, 16:53 | #8 (permalink) |
Member: 2554183 Status: Offline Thanks Meter: 1 | I’m new user of OCTOPLUS box. I downloaded the firmware on OCTOPLUS support area. When I try to flash the phone there is an issue. I see on post above to flash modem. I flash it with this I found in firmware, now baseband crash, when I try to downgrade firmware without sboot check. it works but my baseband crashes can’t unlock it anymore. Sent from my iPhone using Tapatalk |
03-22-2019, 17:25 | #10 (permalink) |
Member: 2554183 Status: Offline Thanks Meter: 1 | Welcome to Octoplus Box Samsung software version 2.7.4 ----------------------------------------------------------------------------------- To connect SGH-T989 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090# or *#0808#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-J120AZ phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-J120AZ Operation: Read info Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-J120AZ Firmware compiled date: Fri Oct 14 14:35:10 KST 2016 PDA version: J120AZTUU2APJ2 CSC version: J120AZAIO2APJ2 SW version: unknown Phone SN: R58J61045DW Android version: 6.0.1 (MMB29K) Sales code: AIO Country: USA HW platform: exynos3 HW Chip: exynos3475 HW Modem: unknown Security patch level: 2016-10-01 Warranty Void: 0 SIM 1 status: not ready Codename: j1xltetu Performed by 2.7.4 Software version. |
03-22-2019, 17:27 | #11 (permalink) | |
Member: 2554183 Status: Offline Thanks Meter: 1 | Quote:
Samsung galaxy sm-j120az Sent from my iPhone using Tapatalk | |
03-23-2019, 08:28 | #12 (permalink) | |
If after of writing all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). | |
03-25-2019, 09:36 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | If after of writing all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). |
