05-14-2016, 16:43 | #1 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Sylhet Bangladesh
Member: 2145140 Status: Offline Sonork: 100.1650938 Thanks Meter: 90 | SM-J200H FRP Lock Remove Successful Selected port: COM68 Selected model: SM-J200H To put SM-J200H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Reset operation completed! Performed by 2.2.6 software version Last edited by Octopus box; 05-14-2016 at 17:17. |
05-30-2016, 16:42 | #3 (permalink) | |
No Life Poster Join Date: Mar 2010 Location: Abidjan,ivory coast
Member: 1272267 Status: Offline Sonork: 100.1667652 Thanks Meter: 408 | Quote:
To connect SM-J200H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM47 Selected model: SM-J200H To put SM-J200H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.2.6 software version | |
05-30-2016, 16:48 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. You can try to reflash the phone with older (by release date) firmware, then repeat "Reset FRP/Reactivation/EE" operation. |
07-28-2016, 13:12 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You can try to use any firmware from the Support Area. |
07-28-2016, 14:01 | #7 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Georgia GE
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | Thank you Tested: Code: INFO : 7/28/2016 16:59:50 > Platform: Samsung Android INFO : 7/28/2016 16:59:50 > Selected port: COM1 INFO : 7/28/2016 16:59:50 > Selected model: SM-J200H WARN : 7/28/2016 16:59:50 > To put SM-J200H into Download Mode, You have to perform the following steps: WARN : 7/28/2016 16:59:50 > 1. Reconnect the battery. WARN : 7/28/2016 16:59:50 > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 7/28/2016 16:59:50 > 3. When phone turns on, press "Volume+" key. INFO : 7/28/2016 16:59:50 > Searching for a phone. Please wait... INFO : 7/28/2016 16:59:50 > Phone found. INFO : 7/28/2016 16:59:50 > Initializing.. INFO : 7/28/2016 16:59:50 > Resetting FRP lock.. SUCC : 7/28/2016 16:59:50 > success INFO : 7/28/2016 16:59:50 > Resetting EE lock.. SUCC : 7/28/2016 16:59:50 > success INFO : 7/28/2016 16:59:50 > Resetting Samsung Account lock.. ERROR : 7/28/2016 16:59:50 > not supported WARN : 7/28/2016 16:59:50 > Reset operation completed! INFO : 7/28/2016 16:59:52 > Performed by 2.3.1 software version Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\28-07-2016_16-30-15.log" closed (7/28/2016 17:00:14). |
The Following User Says Thank You to IkaMazini For This Useful Post: |
06-17-2019, 12:36 | #8 (permalink) |
Freak Poster Join Date: Oct 2018 Location: Kinshasa DRC
Member: 2870691 Status: Offline Thanks Meter: 75 | Select G920T 1000000 percent tested Hello Team, here the log Platform: Samsung Android Selected port: COM110 Selected model: SM-G920T Operation: Reset FRP - UserData Reset FRP/ Reactivation lock operation for SM-G920T will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-G920T into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.8.0 Software version. |
The Following 2 Users Say Thank You to Carocorp14 For This Useful Post: |
