06-02-2017, 22:07 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | SM-J320A read codes done without rooting ----------------------------------------------------------------------------------- To connect SM-J321AZ phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-J320AZ phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-J320A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM15 Selected model: SM-J320A Searching for a phone. Please wait... Found phone on COM3576 Reading info... Detected phone model: SM-J320A HW Version: SM2J320AZACATT PDA version: J320AUCU2APJ2 CSC version: J320AATT2APJ2 CP version: J320AUCU2APJ2 Phone SN: R28J11F892T Phone IMEI: 357417-07-929000-8 Reading HWID...OK Reading NV data...OK Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 52926253 NET LOCK unlock code: 69752483 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:00:34 Performed by 2.5.4 Software version. Last edited by Octopus box; 06-03-2017 at 09:35. |
The Following User Says Thank You to Gambitv01 For This Useful Post: |
