Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 07-13-2018, 23:11   #1 (permalink)
Member: 2765995
Thanks Meter: 8
Smile SM-G930F 8.0 FRP Remove question [Solved]
have a g930f on 8.0 - tried UART to remove ,
tried combinmation
but just cant shift it anyone have any pointers plz
PDA: G930FXXU2EREM [may 2018, revM]
Old 07-13-2018, 23:24   #2 (permalink)
Member: 2273195
Sonork: chavda9900
Thanks Meter: 5
Can you show me logs of ufs
Old 07-13-2018, 23:37   #3 (permalink)
Member: 2765995
Thanks Meter: 8
Welcome to Octoplus Box Samsung software version 2.6.9
To connect SM-G930F phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
Platform: Samsung Android
Selected port: COM26
Selected model: SM-G930F
Operation: Reset FRP - UART UFS
Please put the phone into Download Mode and connect USB cable.
Waiting for phone...
Reading PIT...
PIT was read successfully.
Searching for UART interface.. COM26
Connect Samsung Micro UART cable(with 525K resistor), press and
hold "Vol-" + "Power" buttons for 15-20 seconds
Searching for device. Please wait...
Resetting FRP lock..
FRP / Reactivation lock is successfully reseted!
Performed by 2.6.9 Software version.
Old 07-13-2018, 23:39   #4 (permalink)
Member: 2765995
Thanks Meter: 8
doing UART in combination worked the treat
Old 07-13-2018, 23:39   #5 (permalink)
Member: 2273195
Sonork: chavda9900
Thanks Meter: 5
After reset successful still same condition ??
Sent from my SM-A510F using Tapatalk
Old 07-13-2018, 23:50   #6 (permalink)
Member: 2765995
Thanks Meter: 8
no account wiped
process i used
flash working combination
then run uart process
flash stock
and all is removed
Old 07-13-2018, 23:53   #7 (permalink)
Member: 2273195
Sonork: chavda9900
Thanks Meter: 5
Well done
Originally Posted by roli1980 View Post
no account wiped
process i used
flash stock
and all is removed
Old 07-14-2018, 17:41   #8 (permalink)
Member: 2254384
Thanks Meter: 5
hello, what combination file u use?
Old 07-15-2018, 20:50   #9 (permalink)
Member: 2765995
Thanks Meter: 8
G930FXXU2ARA2
available in download section
Old 07-16-2018, 01:30   #10 (permalink)
Member: 2841276
Thanks Meter: 14
Use combination G930FXXU2ARA2
turn on oem unlock and usb debugging
press reset frp button or use minimal adb and type the commands
adb shell content insert --uri
adb shell content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1
Old 07-17-2018, 16:30   #11 (permalink)
Member: 1010981
Sonork: 100.1614537
Thanks Meter: 47
After flahs with this my phone enter in <bootloader exception>
Old 07-18-2018, 12:50   #12 (permalink)
Member: 158975
Thanks Meter: 17
not working with combination.
folow this steps :
1.downgrade to G930FXXU2DRB6_OJV2DRAG
2.wipe from recovery, else error storage will apear
3. frp reset using uart
4. back to original fw
br, cris
Old 07-19-2018, 14:54   #13 (permalink)
Member: 1281173
Thanks Meter: 4
not enter donwloader mode , pl, help
Page generated in 0.24992 seconds with 9 queries
