08-17-2016, 12:25 | #1 (permalink) |
Freak Poster Join Date: Nov 2011 Location: karachi
Member: 1686673 Status: Offline Thanks Meter: 53 | SM J500F Certificate failed [Solved] Dear Sir How to write Certificate File On SM J500F I M try Many Time But Show Same Error Plz See This Image And tell me How to Write Certificate File Thanks Last edited by Octopus box; 08-18-2016 at 11:34. |
08-17-2016, 12:49 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Extract the file from an archive, then repeat "Write Cert" operation. Post here full Software log of the operation. |
08-17-2016, 13:02 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please manually change extension of the file to "cert", or send us the file, we will change it for You. |
08-17-2016, 13:08 | #7 (permalink) |
Member: 1686673 Status: Offline Thanks Meter: 53 | SIr This Setup is Already Do it but Not Done here is file J500F_35214107033667 - Download - 4shared - Naveed Ahmed |
The Following User Says Thank You to Khan-jee For This Useful Post: |
08-17-2016, 13:24 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Most likely the file was manually edited. Any changes in cert file corrupts it and makes no longer usable. Try to write another Cert file. |
08-17-2016, 13:27 | #10 (permalink) |
Member: 1686673 Status: Offline Thanks Meter: 53 | Ok Sir Can Give Me other Cert File ???????? Here is one More Cert File But Same Error SM-J500F_CERT_BY_GSM_RASHID - Download - 4shared - mdrashid 78692 Last edited by Octopus box; 08-17-2016 at 14:07. |
08-17-2016, 14:07 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | This is the same Cert file, but with different title. If You don't have second correct cert file - You can make a copy of the one which You have and use it as a second Cert file. |
08-18-2016, 10:29 | #13 (permalink) | |
Member: 1686673 Status: Offline Thanks Meter: 53 | Quote:
Thank You sir This Setup is Working Fine I M Successfully Write Cert File but one Question I m copy Cert File After Write Duel Imei is Same can you tell me How to Fix this problem | |
08-18-2016, 10:57 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | IMEI is the same because You've used the same Cert file. To fix this problem, You need to use different Cert files. |
