05-10-2016, 11:51 | #1 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Banjul, The Gambia
Member: 1974557 Status: Offline Sonork: 00011nd Thanks Meter: 39 | Sm-j700f frp failed i have tried several times, and it kept failling. Welcome to Octoplus/Octopus Box Samsung software version 2.2.4 ----------------------------------------------------------------------------------- To connect SM-J700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM40 Selected model: SM-J700F To put SM-J700F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock.. Operation was failed! Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM40 Selected model: SM-J700F To put SM-J700F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock.. Operation was failed! Performed by 2.2.4 software version |
05-10-2016, 13:18 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Unfortunately currently no stable solution for FRP lock removal for SM-J700F with new firmwares. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. You can try to use solution suggested by mr.khudda1234 here: http://forum.gsmhosting.com/vbb/f684...46/index2.html Another solution was suggested by mr.calvinpower here: http://forum.gsmhosting.com/vbb/f684...oblem-2080233/ |
