03-16-2016, 15:52 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bangladesh
Member: 387110 Status: Offline Sonork: Not Use Thanks Meter: 630 | SM-J700h/DS after flash fully dead Code: Welcome to Octoplus/Octopus Box Samsung software version 2.2.2 ----------------------------------------------------------------------------------- To connect SM-J700H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. Selected firmware file: j700hxxu1aogb_j700holb1aog1_xxv_android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-J700H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Firmware writing successfully completed. Performed by 2.2.2 software version Need Proper suggestions. |
The Following User Says Thank You to Dilip_Nath For This Useful Post: |
03-16-2016, 16:12 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | Hello. What was initial state of the phone? Why did You decide to reflash it? Please fully charge phone's battery, then check whether phone enters Download Mode. |
03-17-2016, 05:05 | #6 (permalink) | |
Member: 387110 Status: Offline Sonork: Not Use Thanks Meter: 630 | Quote:
Phone don't enter Download Mode by any way. wbr Dilip | |
03-17-2016, 06:06 | #9 (permalink) |
Freak Poster Join Date: Mar 2012 Location: Sweden/Stockholm
Member: 1736454 Status: Offline Thanks Meter: 82 | REMEMBER ONE IMPORTANT THING!!! The Phone is DEAD because OLDER sboot.bin was written to it. To successfully repair it, you need to always use the NEWEST Flash Files and avoid using OLD Flash Files. check here |
03-17-2016, 12:03 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | Unfortunately, if phone does not enter Download Mode, it can't be processed with Octoplus/Octopus Samsung Software. You need to repair phone's boot loaders via JTAG/eMMC. |
