04-22-2018, 16:21 | #1 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Pakistan
Member: 1674109 Status: Offline Thanks Meter: 36 | SM-J710F IMEI repair problem [Answered] ----------------------------------------------------------------------------------- To connect SM-G570F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-J710F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: J710FXXU3BQHE_J710FOJV3BQHE_XSG_Android_7.0.oct Please put the phone into Download Mode and connect USB cable. To put SM-J710F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.6.8 Software version. ----------------------------------------------------------------------------------- To connect SM-J710FD phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-J710FD Operation: Repair IMEI A Proper android device not found. Make shure that "USB debug" option on the device is turned on. IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. Performed by 2.6.8 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-J710FD Operation: Repair IMEI A Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-J710F Firmware compiled date: Wed Jan 10 14:49:27 KST 2018 PDA version: J710FXXU4BRA2 CSC version: J710FOJV4BRA1 SW version: J710FXXU4BRA5 Phone SN: RF8H60QNGWP Android version: 7.0 (NRD90M) Sales code: PAK Country: PAKISTAN HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2018-01-01 SIM 1 status: ready SIM 2 status: absent Codename: j7xeltexx Checking Root: Write IMEI failed Performed by 2.6.8 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-J710FD Operation: Repair IMEI A Detected phone model: SM-J710F Firmware compiled date: Wed Jan 10 14:49:27 KST 2018 PDA version: J710FXXU4BRA2 CSC version: J710FOJV4BRA1 SW version: J710FXXU4BRA5 Phone SN: RF8H60QNGWP Android version: 7.0 (NRD90M) Sales code: PAK Country: PAKISTAN HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2018-01-01 SIM 1 status: ready SIM 2 status: absent Codename: j7xeltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-J710FD-RF8H60QNGWP-22-04-2018_18-43- 13-.asec file Connecting to modem port... Found phone on COM329 Reading data from phone... Could not read data from modem port, trying with exploit.. Initializing exploit... Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Phone found. Executing exploit... Exploit has been executed successfully New IMEI: 350175534345455 Writing new phone IMEI... Invalid security image! Write IMEI failed Performed by 2.6.8 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM329 Selected model: SM-J710FD Operation: Repair IMEI B Detected phone model: SM-J710F Firmware compiled date: Wed Jan 10 14:49:27 KST 2018 PDA version: J710FXXU4BRA2 CSC version: J710FOJV4BRA1 SW version: J710FXXU4BRA5 Phone SN: RF8H60QNGWP Android version: 7.0 (NRD90M) Sales code: PAK Country: PAKISTAN HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2018-01-01 SIM 1 status: ready SIM 2 status: absent Codename: j7xeltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-J710FD-RF8H60QNGWP-22-04-2018_18-47- 41-.asec file Connecting to modem port... Found phone on COM329 Reading data from phone... Could not read data from modem port, trying with exploit.. Initializing exploit... Executing exploit... Exploit has been executed successfully New IMEI: 350145354487901 Writing new phone IMEI... Invalid security image! Write IMEI failed Performed by 2.6.8 Software version. Last edited by Octopus box; 04-22-2018 at 18:00. |
04-22-2018, 17:59 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. As You can see from your Software log, security of your device is damaged: Quote:
Also try to re-flash the phone with different firmwares, root it using TWRP + SuperSU and then repeat "Repair IMEI" operation. | |
