Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 01-10-2019, 11:28   #1 (permalink)
NST-Thina's Avatar
Member: 2372779
Sonork: 100.1680276
Thanks Meter: 33
SM-J730F no supports Single-SKU
This device came to Bootloop case
I Flash it with Octoplus Firmware then this problem
then i flash another 2 Firmware Downloaded From Sammobile
1 time is working properly after few minutes restarting the phone 2 times now phone is not working only showing SAMSUNG Logo And this Error
Please Help me What happen this device? What can i do for Fix this device
Photos Bellow
Old 01-10-2019, 11:32   #2 (permalink)
Crazy Poster
Member: 2765301
Thanks Meter: 7
Photos Bellow
Try to flash 4 files firmware...
Sent from my SM-G610F using Tapatalk
The Following User Says Thank You to faizan453 For This Useful Post:
Old 01-10-2019, 11:35   #3 (permalink)
Member: 1987265
Sonork: 100.1651707
Thanks Meter: 10
sent me
will do something
take hour
Ok dance
The Following User Says Thank You to gsm_arif For This Useful Post:
Old 01-10-2019, 11:41   #4 (permalink)
Member: 2613252
Thanks Meter: 1,837
Photos Bellow
Hello, if you read the error on the phone screen
failed to mount/cache efs invalid argument
you have the efs damaged for that the phone does not start.
to restart it in normal mode you have to write the efs through octopus software if supported, or using odin in ap mode
The Following User Says Thank You to amleto90 For This Useful Post:
Old 01-10-2019, 11:54   #5 (permalink)
NST-Thina's Avatar
Member: 2372779
Sonork: 100.1680276
Thanks Meter: 33
phone can't turn On normal only Download mode only how to write efs ?
Old 01-10-2019, 11:58   #6 (permalink)
Member: 2613252
Thanks Meter: 1,837
Yes, if you have a backup of the j730f efs in tar format you can write it by putting the phone in download mode or with octopus software if the writing of the efs is supported or using odin by selecting the voice ap
Old 01-11-2019, 02:13   #7 (permalink)
Member: 1421034
Similar problem with corupted efs
Hi! I have a similar problem, after flashing latest stock FW (J730FXXU3BRJ1_J730FMOT3BRJ1_MOT.zip) I get recovery bootloop, first is doing update system, after second boot I only see NO COMMAND with android ! mark.
After flashing EFS-SM-J730F-18-04-2018_10-59-20.tar I get:
(se pic)
There is another problem, somehow OEM lock went back, so I cannot flash custom recovery thos custom system.
I tried COMBINATION_OXA_FA70_J730FXXU3ARI1_OXAFAC_CL128616 01_QB19739866_REV00_user_mid_noship.tar
This is the only system that I can boot with OEM lock ON, but here there is no OEM unlock option in developer options, I only get limited ADB with no ROOT functionality...
Any ideas?
Tnx
Grga
Old 01-11-2019, 11:16   #8 (permalink)
Member: 2620145
Thanks Meter: 319
repair drk will be fine
Old 01-12-2019, 14:38   #9 (permalink)
Member: 1421034
No DRK fix option in OBSS v2.7.7 for J730F (;
Old 01-12-2019, 16:13   #10 (permalink)
Member: 2613252
Thanks Meter: 1,837
Hello,try to select another model other than j730f from octopus software which provides drk repair, install the combination and repair the drk.
using the uart cable to repair the drk and selecting a model that provides the repair drk via uart cable.
Old 01-12-2019, 17:44   #11 (permalink)
Member: 1421034
Like G930F? (no model checking in uart mode?)
Is this baseband unknown also drk related?
Because I can Write Sec, Write EFS, Repair network, but i stiil get baseband unknown?
Tried write cert but tis fails probably because drk and android 8.1?
Platform: Samsung Android
Selected port: COM11
Selected model: SM-J730F
Operation: Write Cert
Selected file: E:\J730F\....cert
Detected phone model: SM-J730F
Firmware compiled date: Wed Nov 14 22:24:18 KST 2018
PDA version: J730FXXU3BRK2
CSC version: J730FMOT3BRK2
SW version: unknown
Phone SN: ........
Android version: 8.1.0 (M1AJQ)
Sales code: MOT
Country: Slovenia
HW platform: exynos5
HW Chip: exynos7870
HW Modem: unknown
Security patch level: 2018-11-01
Warranty Void: 0
Codename: j7y17ltexx
Checking Root:
Phone is Rooted.
Reading security backup, please wait...
Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP
\Security-SM-J730F-....-12-01-2019_17-15-14-.asec file
Initializing exploit...
Executing exploit...
Writing Certificate failed
Performed by 2.7.7.1 Software version.
Old 01-12-2019, 18:02   #12 (permalink)
Member: 2613252
Thanks Meter: 1,837
SW version: unknown
Phone SN: ........
Sales code: MOT
Country: Slovenia
HW Chip: exynos7870
HW Modem: unknown
Warranty Void: 0
Checking Root:
Phone is Rooted.
reading your post and the photo you posted previously of the j730f phone the problem was the error drk after you wrote the efs, you wrote in the post that you tried to make the root but it was impossible because of the blocked oem, then you're managed to do the fix of the drk by doing the root or using another method is another matter.
I wrote you try to repair the drk via cable uart selected another model because j730f is not supported by octopus for repair drk, nothing else.
You have now posted the octopus software log where it is written that you have the unknown baseband (modem) and are two different things to have the error drk.
If you want to fix the baseband you do not have many alternatives, I try to flash the different binary 3 firmware and see if the baseband is correct or use the combination if these two solutions do not lead to a resolution of the baseband repair, you could have the security of the phone damaged, but unfortunately for j730f the repair of security or writing security backup is not supported or it may be a hardware problem of the phone
Old 01-12-2019, 18:59   #13 (permalink)
Member: 1421034
No hardware fault, I had to erase EFS manually, from custom recovery, now it works fine...
If something is not supported it shoud be greyyed out, we are all loosing time not knowing if some function is working or not...
Old 01-14-2019, 09:01   #14 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,406
The Write Cert same as Repair IMEI operations aren't supported on this Android version.
The Following User Says Thank You to Octopus box For This Useful Post:
Page generated in 0.26304 seconds with 8 queries
