02-02-2018, 18:15 | #1 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: 46000
Member: 197566 Status: Offline Thanks Meter: 89 | SM-J730F unlock problem [Solved] ----------------------------------------------------------------------------------- Quote:
02-03-2018, 10:18 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. In the latest firmware versions Samsung close security hole and You can't perform Direct Unlock or Write Cert on new version of firmwares. You can try to downgrade phone's firmware (write older, by release date, version of firmware) but on your own risk, after repeat Unlock or Write Cert operations. |
02-12-2018, 15:03 | #5 (permalink) |
Freak Poster Join Date: Feb 2013 Location: dhaka
Member: 1890442 Status: Offline Sonork: 100.1621735 Thanks Meter: 39 | SM-J730F unknoun baseband during unlock, how can i repair baseband pls help me |
The Following User Says Thank You to rajbonshi20 For This Useful Post: |
02-12-2018, 15:16 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). If after of writing all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). |
02-22-2018, 01:21 | #8 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1866320 Status: Offline Sonork: amoodie1 Thanks Meter: 0 | Dear all i had downgrade the security patch from 01-01-2018 to 01-07-2017 but help me please while unlocking its saying try to downgrade modem i flash with downgrade modem/cp file and after that its not showing imei but when upgrade or flash with cp file its showing imei now what to do help me team thanks in advance |
02-22-2018, 06:20 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If after writing firmware or modem file phone's IMEI disappears, this means, that modem firmware is not compatible for your device revision. In this case You should try to write other firmwares. |
