02-09-2015, 15:35 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Read out phone's info via ADB (turn on USB Debugging mode in the phone and press "Read info" button at "Android / EFS manager" tab in the Software) and post here full Software log with this info. |
02-09-2015, 16:15 | #5 (permalink) |
Freak Poster Join Date: Aug 2009 Location: sri lanka
Member: 1097092 Status: Offline Thanks Meter: 12 | Platform: Samsung Android Selected port: COM7 Selected model: SM-N9005 Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-N9005 Firmware compiled date: Tue Mar 4 13:48:22 KST 2014 PDA version: N9005XXUENC2 CSC version: N9005OLBENC2 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) |
02-09-2015, 16:17 | #6 (permalink) |
Member: 1097092 Status: Offline Thanks Meter: 12 | flash lpg Found phone on Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. |
02-09-2015, 16:26 | #7 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | As You can see from your Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair EFS" and "Repair IMEI" (or Wipe Security and Write Cert) operations. It is not possible to repair IMEI (or Write Cert), if phone's modem part is damaged. If after of writing all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). | |
02-11-2015, 15:20 | #10 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Quote:
02-11-2015, 16:02 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | If after of writing all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). |
