01-13-2016, 06:29 | #1 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Yangon Age: 29
Member: 2006794 Status: Offline Sonork: 100.1664636 Thanks Meter: 164 | Sm-N900L writing cert failed ----------------------------------------------------------------------------------- To connect SM-N900L phone you have to perform the following steps: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-N900L Detected phone model: SM-N900L Firmware compiled date: Wed Mar 4 18:59:43 KST 2015 PDA version: N900LKLU0GOC4 CSC version: N900LLGT0GOC4 SW version: N900LKLU0GOB6 Phone SN: 00000000000 Android version: 5.0 (LRX21V) Updating DIAG confing... DIAG confing is succesfully enabled. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM68 Selected model: SM-N900L Selected file: C:\Program Files\Z3X\Samsung\SamsungToolPRO\backup\Cert\SM-N900_358916055989060_R51F80DGH9H_13-1-2016_11-26-59.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM68 Selected model: SM-N900L Selected file: C:\Program Files\Z3X\Samsung\SamsungToolPRO\backup\Cert\SM-N900_358916055989060_R51F80DGH9H_13-1-2016_11-26-59.cert Detected phone model: SM-N900L Firmware compiled date: Wed Mar 4 18:59:43 KST 2015 PDA version: N900LKLU0GOC4 CSC version: N900LLGT0GOC4 SW version: N900LKLU0GOB6 Phone SN: 00000000000 Android version: 5.0 (LRX21V) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Please Reset MSL first! Writing Certificate failed ----------------------------------------------------------------------------------- To connect SM-N900P phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N900S phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N900K phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N9005 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM68 Selected model: SM-N9002 Reading info... Mode: Normal Firmware compiled date: Jan 06 2014 Firmware compiled time: 19:00:00 Firmware released date: Feb 23 2015 Firmware released time: 21:53:32 SW Version: M8974A-AAAANAZM-1.0.180104 Reseting MSL... MSL reset successfully. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM68 Selected model: SM-N9002 Reading info... Mode: Normal Firmware compiled date: Jan 06 2014 Firmware compiled time: 19:00:00 Firmware released date: Feb 23 2015 Firmware released time: 21:53:32 SW Version: M8974A-AAAANAZM-1.0.180104 Reseting MSL... MSL reset successfully. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM68 Selected model: SM-N9002 Reading info... Mode: Normal Firmware compiled date: Jan 06 2014 Firmware compiled time: 19:00:00 Firmware released date: Feb 23 2015 Firmware released time: 21:53:32 SW Version: M8974A-AAAANAZM-1.0.180104 Reseting MSL... MSL reset successfully. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- To connect SM-N900L phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM68 Selected model: SM-N900L Selected file: C:\Users\Win Aung\Downloads\Cert-SM-N9000Q_354305060520553_R51F80V8C3.cert Operation was canceled Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM68 Selected model: SM-N900L Selected file: C:\Users\Win Aung\Downloads\Cert-SM-N9000Q_354305060520553_R51F80V8C3.cert Selected file: C:\Users\Win Aung\Documents\百度云同步盘\BOX\G900F cert\Cert-SM-N900-358021057834883-00000000000.cert Detected phone model: SM-N900L Firmware compiled date: Wed Mar 4 18:59:43 KST 2015 PDA version: N900LKLU0GOC4 CSC version: N900LLGT0GOC4 SW version: N900LKLU0GOB6 Phone SN: 00000000000 Android version: 5.0 (LRX21V) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Writing Certificate failed Last edited by Octopus box; 01-13-2016 at 10:37. |
01-13-2016, 10:39 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please do the next: 1. Install the latest Software version. 2. Perform "Wipe Security" operation. 3. Repeat "Write Cert" operation. Post here result and full Software log of performed operations. |
01-14-2016, 09:02 | #3 (permalink) |
Member: 2006794 Status: Offline Sonork: 100.1664636 Thanks Meter: 164 | Welcome to Octoplus/Octopus Box Samsung software version 2.1.6 ----------------------------------------------------------------------------------- To connect SM-N900L phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-N900L Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-N900L Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-N900L Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-N900L Operation was canceled Writing EFS was canceled. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-N900L Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-N900L Reading info, please wait... Detected phone model: SM-N900L Firmware compiled date: Wed Mar 4 18:59:43 KST 2015 PDA version: N900LKLU0GOC4 CSC version: N900LLGT0GOC4 SW version: N900LKLU0GOB6 Phone SN: 00000000000 Android version: 5.0 (LRX21V) ----------------------------------------------------------------------------------- To connect SM-N900 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-N9005 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N900L phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-N900L Detected phone model: SM-N900L Firmware compiled date: Wed Mar 4 18:59:43 KST 2015 PDA version: N900LKLU0GOC4 CSC version: N900LLGT0GOC4 SW version: N900LKLU0GOB6 Phone SN: 00000000000 Android version: 5.0 (LRX21V) Reading info... Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-N900L Detected phone model: SM-N900L Firmware compiled date: Wed Mar 4 18:59:43 KST 2015 PDA version: N900LKLU0GOC4 CSC version: N900LLGT0GOC4 SW version: N900LKLU0GOB6 Phone SN: 00000000000 Android version: 5.0 (LRX21V) Updating DIAG confing... DIAG confing is succesfully enabled. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: Selected model: SM-N900L Reading info, please wait... Detected phone model: SM-N900L Firmware compiled date: Wed Mar 4 18:59:43 KST 2015 PDA version: N900LKLU0GOC4 CSC version: N900LLGT0GOC4 SW version: N900LKLU0GOB6 Phone SN: 00000000000 Android version: 5.0 (LRX21V) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: Selected model: SM-N900L Detected phone model: SM-N900L Firmware compiled date: Wed Mar 4 18:59:43 KST 2015 PDA version: N900LKLU0GOC4 CSC version: N900LLGT0GOC4 SW version: N900LKLU0GOB6 Phone SN: 00000000000 Android version: 5.0 (LRX21V) Reading info... Mode: Normal Firmware compiled date: Jan 06 2014 Firmware compiled time: 19:00:00 Firmware released date: Feb 23 2015 Firmware released time: 21:53:32 SW Version: M8974A-AAAANAZM-1.0.180104 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-N900L-14-01-2016_11-02-16-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N900L-14-01-2016_11-06-01-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! Reading info... Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: Selected model: SM-N900L ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: Selected model: SM-N900L Reading info, please wait... ADB server killed. Detected phone model: SM-N900L Firmware compiled date: Wed Mar 4 18:59:43 KST 2015 PDA version: N900LKLU0GOC4 CSC version: N900LLGT0GOC4 SW version: N900LKLU0GOB6 Phone SN: 00000000000 Android version: 5.0 (LRX21V) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: Selected model: SM-N900L Selected file: C:\Users\Win Aung\Documents\百度云同步盘\BOX\G900F cert\Cert-SM-N900-358021057834883-00000000000.cert Detected phone model: SM-N900L Firmware compiled date: Wed Mar 4 18:59:43 KST 2015 PDA version: N900LKLU0GOC4 CSC version: N900LLGT0GOC4 SW version: N900LKLU0GOB6 Phone SN: 00000000000 Android version: 5.0 (LRX21V) Checking Root: Phone is Rooted. Checking Certificate file... Checking Certificate failed Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: Selected model: SM-N900L Selected file: C:\Users\Win Aung\Documents\百度云同步盘\BOX\G900F cert\Cert-SM-N900-358021057834883-00000000000.cert Detected phone model: SM-N900L Firmware compiled date: Wed Mar 4 18:59:43 KST 2015 PDA version: N900LKLU0GOC4 CSC version: N900LLGT0GOC4 SW version: N900LKLU0GOB6 Phone SN: 00000000000 Android version: 5.0 (LRX21V) Checking Root: Phone is Rooted. Checking Certificate file... Checking Certificate failed Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: Selected model: SM-N900L Selected file: C:\Users\Win Aung\Downloads\Cert-SM-N9000Q_ 354305060520553_R51F80V8C3.cert Detected phone model: SM-N900L Firmware compiled date: Wed Mar 4 18:59:43 KST 2015 PDA version: N900LKLU0GOC4 CSC version: N900LLGT0GOC4 SW version: N900LKLU0GOB6 Phone SN: 00000000000 Android version: 5.0 (LRX21V) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: Selected model: SM-N900L Operation was canceled Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: Selected model: SM-N900L Selected file: C:\Users\Win Aung\Documents\百度云同步盘\BOX\G900F cert\All Cert By Qcn File Download free\CERTF\SM-N900_ 358021059721922_Venezuela.cert Detected phone model: SM-N900L Firmware compiled date: Wed Mar 4 18:59:43 KST 2015 PDA version: N900LKLU0GOC4 CSC version: N900LLGT0GOC4 SW version: N900LKLU0GOB6 Phone SN: 00000000000 Android version: 5.0 (LRX21V) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Writing Certificate failed |
The Following User Says Thank You to otherboy123 For This Useful Post: |
