11-14-2014, 07:52 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Yes, Repair IMEI is currently not supported for this device model. But, as You can see from your Software log, phone's modem part is damaged in your device. Quote:
You should re-flash the device with different firmwares (with Android 4.4.2 or higher) and check, whether modem (baseband) is correct (SW version is not Unknown). When phone's modem part will be correct, check IMEI and write here, whether IMEI became correct. | |
02-15-2015, 00:04 | #3 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2286971 Status: Offline Thanks Meter: 1 | Ok, i got my OCTOBUS BOX and i try to gsm unlock N900P . The phone is updated to 4.4.4 version . I did some changes in service mode to switch to phone on GSM mode including downgrade the modem and SSC for the simcard. Also i install N900T rom . The phone is still searching for network Do i need to upgrade the Modem ??? So far i got this : i attach some screen shots |
02-15-2015, 10:02 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | To unlock your device try to perfrom this free solution: http://forum.gsmhosting.com/vbb/f777...-free-1876915/. |
02-17-2015, 04:24 | #7 (permalink) |
Freak Poster Join Date: Nov 2013 Location: remotely
Member: 2063388 Status: Offline Thanks Meter: 80 | Domestic Sim Unlock For T-Mobile/AT&T or… | Sprint Samsung Galaxy Note 3 | XDA Forums yes you need a active gsm sim card ! and yes you need to downgrade the modem if your trying to use in the usa . and will need to be in 4.4.2 to downgrade the modem |
