06-02-2014, 19:23 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. We have not tested Repair IMEI with exactly this firmware, but we had a lot of reports about successful repair of SM-N900T's IMEI that were running Android 4.4.2. You can try to make Repair IMEI carefully following the steps, that are described in manual for this phone (press "Help" button in software) and post here the results. |
06-02-2014, 20:54 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | If operation stucks on "Searching phone" when phone was connected via UART cable - try to use another Samsung Micro UART C3300k/C3303k cable with 523-525 kOhm resistor inside. Also try to use another box as UART interface with Samsung Micro UART cables You have. Currently no another solution. |
06-03-2014, 06:23 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | At first, try to perform the operatin by using another Samsung Micro UART C3300k/C3303k cable with 523-525 kOhm resistor inside and post here full Software log. Also try to use another box as UART interface with Samsung Micro UART cables You have. Also, look here: http://forum.gsmhosting.com/vbb/f684...olved-1821642/. |
