02-10-2015, 04:18 | #1 (permalink) |
Freak Poster Join Date: May 2014 Location: from JORD . work in usa .
Member: 2179929 Status: Offline Thanks Meter: 34 | SM-N900T No service after Write Cert ----------------------------------------------------------------------------------- To connect SM-G900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM25 Selected model: SM-G900T Reading info, please wait... ADB server killed. Detected phone model: SM-G900T Firmware compiled date: Fri May 23 20:23:24 KST 2014 PDA version: G900TUVU1ANE6 CSC version: G900TTMB1ANE6 SW version: G900TUVU1ANE6 Phone IMEI: Unknown Phone SN: RV8F41N823A Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM25 Selected model: SM-G900T Selected file: C:\Users\baraa\Desktop\Cert-SM-G900T_ 352558067456419_00000000000.cert Detected phone model: SM-G900T Firmware compiled date: Fri May 23 20:23:24 KST 2014 PDA version: G900TUVU1ANE6 CSC version: G900TTMB1ANE6 SW version: G900TUVU1ANE6 Phone IMEI: Unknown Phone SN: RV8F41N823A Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM25 Selected model: SM-G900T Reading info, please wait... ADB server killed. Detected phone model: SM-G900T Firmware compiled date: Fri May 23 20:23:24 KST 2014 PDA version: G900TUVU1ANE6 CSC version: G900TTMB1ANE6 SW version: G900TUVU1ANE6 Phone IMEI: 352558067456419 Phone SN: RV8F41N823A Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM25 Selected model: SM-G900T Reading info... Mode: Normal Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: May 23 2014 Firmware released time: 19:41:46 SW Version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 Operation was canceled Writing QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM25 Selected model: SM-G900T Mode: Normal Phone model: SM-G900T Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: May 23 2014 Firmware released time: 19:41:46 Phone IMEI: 352558-06-745641-9 SW version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM25 Selected model: SM-G900T Mode: Normal Phone model: SM-G900T Firmware compiled date: May 10 2014 Firmware compiled time: 03:00:00 Firmware released date: May 23 2014 Firmware released time: 19:41:46 Phone IMEI: 352558-06-745641-9 SW version: MPSS.DI.2.0.1.c2-00055-M8974AAAAANRZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM25 Selected model: SM-G900T Reading info, please wait... Detected phone model: SM-G900T Firmware compiled date: Fri May 23 20:23:24 KST 2014 PDA version: G900TUVU1ANE6 CSC version: G900TTMB1ANE6 SW version: G900TUVU1ANE6 Phone IMEI: 352558067456419 Phone SN: RV8F41N823A Android version: 4.4.2 (KOT49H) --------------------------------------------- now the phone is not registered on network ! any hope ? |
02-10-2015, 07:55 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to write QCNs, which we have sent You to PM, then insert SIM card, wait 5-7 minutes and try to find and select network manually. Also try to write other IMEI Certificates, maybe IMEI from the IMEI Certificate file, that You have written, is in the "black" list of your network operator. |
02-13-2015, 07:30 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ bstanomir All Certificates files, which we have, are present in the Support Area (press "Go to Support" button at "Support & Options" tab in the Software) in the folder "Samsung/FOR UNLOCK ANDREPAIR/Certificates/". For SM-N900t and SM-N900p You should use IMEI Certificates from SM-N900 or from SM-N9000Q. |
02-13-2015, 09:21 | #6 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Absolutely false. The QCN is what affects your network. If you wipe out the QCN obviously you won't get network. If the QCN was damaged beforehand and you restore it obviously You won't get network either. You need to write a WORKING QCN to the phone AFTER wiping The efs. That's the ONLY way for a functional network. |
02-15-2015, 02:16 | #7 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2286971 Status: Offline Thanks Meter: 1 | i finally manage to repair my N900P open GSM mode but still searching for network i have some screen shots but i can not post them because i dont have 10 or more post's on forum. N900P version 4.4.4 / open GSM MODE on service menu / downgrade to lower modem /show that is GSM but still "not registered on network. Any advise ? |
02-17-2015, 02:01 | #9 (permalink) |
Member: 2179929 Status: Offline Thanks Meter: 34 | Thanks all for all the advice, the problem was the cert . I was writing a blocked cert file this it . Now I have a clean one and the phone work with 4G LTE without any problems. Bets box you can have |
02-17-2015, 07:38 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ bstanomir To Unlock SM-N900P, You can use thi free solution: http://forum.gsmhosting.com/vbb/f777...-free-1876915/. |
02-18-2015, 03:52 | #13 (permalink) | |
Junior Member Join Date: Nov 2014 Age: 35
Member: 2297259 Status: Offline Thanks Meter: 15 | same Quote:
( searching ) the cert was successfully writed . may i have the QCN´s that you are using to repair please | |
02-18-2015, 07:39 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You can download QCN files from the Support Area from the folder "Samsung/FOR UNLOCK AND REPAIR/QCN". Last edited by Octopus box; 02-20-2015 at 13:47. |
