04-24-2014, 14:01 | #1 (permalink) |
Junior Member Join Date: Aug 2004 Location: GTA Age: 48
Member: 79096 Status: Offline Thanks Meter: 0 | SM N900W8 IMEI restore worked - but shows Emergency calls only [Solved] fixed 3g/4g same issue. using latest 1.5.4 from website on canadian Note 3 tried changing IMEI to service IMEI and changed successfully but again device shows Emergency calls only Last edited by Octopus box; 04-28-2014 at 08:05. |
04-24-2014, 14:07 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have sent You test Software version to PM. Try to make Repair IMEI or Repair 3G/4G with this Software and post here the result. |
04-25-2014, 06:28 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ juujuu710 We have sent You test Software version to PM. Re-flash the phone and make Repair IMEI or Repair 3G/4G with this Software and post here full Software log with all of these actions. |
04-26-2014, 05:37 | #9 (permalink) |
Member: 79096 Status: Offline Thanks Meter: 0 | tried with 1.5.5 repaired ok however still emergency only from service menu IMEI certi: fail Network: BLOCKED I tried pulling the logs but box got disconnected. please advice. please advice.... |
04-28-2014, 07:57 | #11 (permalink) |
Junior Member Join Date: Apr 2014 Location: Toronto, Canada
Member: 2171813 Status: Offline Thanks Meter: 2 | i fixed it =) to fix null imei just need to restore clean nv data to phone and you will get imei 0 /00 and all you gotta do after that is to flash new imei again! if you need a copy of the nv data pm me and i can send it to you =) good luck! |
04-28-2014, 08:15 | #12 (permalink) | |
Member: 2171813 Status: Offline Thanks Meter: 2 | Quote:
www(dot)mediafire(dot)com/download/1oias85eoz8ykuh/Rogers+Modem+%28CP%29(dot)tar ps. forum wont let me post link so please change (dot) to . on your own and it will fix the IMEI certi: fail, Network: BLOCKED problem but after that you probably gonna find your phone working only on 2g network. to fix that... your final step is to to restore clean nv data to get back on 3g/lte network. pm me if u need the nv data file | |
05-02-2014, 15:17 | #13 (permalink) | |
Junior Member Join Date: May 2014
Member: 2178943 Status: Offline Thanks Meter: 0 | NOTE 3 gives imei null and it was from canada ( ROGERS) SM 900/W8 and after unlockin Quote:
please help send me copy of nv as my phone NOTE 3 gives imei null and it was from canada ( ROGERS) SM 900/W8 and after unlocking in egypt via octobus it gives null imei is the phone damaged please help | |
