08-27-2015, 10:34 | #1 (permalink) |
Freak Poster Join Date: Feb 2012 Location: Kathmandu Age: 33
Member: 1721729 Status: Offline Sonork: 100.1623685 Thanks Meter: 28 | SM-N910A Baseband unknown/Bootloop after *#9090# I flashed with both files: Firstly, N910AUCU1BNK3_N910AATT1BNK3_ATT_Android_4.4.4.rar nothing was wrong till here But after flashing with N910AUCU1ANIE_N910AATT1ANIE.oct efs was too corrupt. E:failed to mount /efs (Invalid Argument) while putting in reovery. Now the problem is I found solution for unknown baseband http://forum.gsmhosting.com/vbb/f684...-step-1961415/ but I was unable to enter *#0808# and while looking for problem I found that there was no efs I mean while putting on recovery it says "E:failed to mount /efs (Invalid Argument)" How to revive this set now? I found that many users have same problem, but how to solve this?? |
08-27-2015, 11:10 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. Please, install the latest Software version and re-flash the phone with firmware from the Support Area, then perform "Repair EFS" operation. |
08-28-2015, 08:28 | #4 (permalink) |
Member: 1721729 Status: Offline Sonork: 100.1623685 Thanks Meter: 28 | Well I managed to repair baseband, now I have a different problem. I can't write Cert file on this phone. This is error when I tried with c3303k cable. This is error when I tried with usb cable. P.S I have tried flashing with both files available on support and also tried wiping cache/data. And I already tried with latest oct version 2.0.4 , Actually someone has successed writing cert with 2.0.2 version so I installed and tried with this version but failed. |
08-28-2015, 08:39 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Please, make sure that You block one pin on a battery, accordingly to Software manual, before connect phone via UART cable, to read Software manual press "Help" button in software and read carefully, repeat "Write Cert' operation again and post here results. |
08-28-2015, 08:41 | #6 (permalink) |
Member: 1721729 Status: Offline Sonork: 100.1623685 Thanks Meter: 28 | Without blocking pin Software won't say Phone found. I have already blocked one pin and write certificate but same problem, Platform: Samsung Android Selected port: COM18 Selected model: SM-N910A Selected file: C:\Documents and Settings\fuzion\My Documents\Downloads\Cert-SM-N910A_355694060163020.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM18 Phone connected successfully Checking Certificate file... and then stops. |
08-28-2015, 08:47 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Please contact us to Skype, or Yahoo! Messenger, we will check where can be the problem. Our contacts You can find in our profile. |
10-26-2015, 14:19 | #8 (permalink) |
Junior Member Join Date: Apr 2012 Location: Kiev
Member: 1743802 Status: Offline Thanks Meter: 1 | I have a problem with bootloop n910a after *#9090#. I have already installed all the firmwares from the support page - it does not help me. How can I solve this problem? Octopus team, please help me. |
10-26-2015, 14:24 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Re-flash the phone with firmware from the Support Area, then perform "Repair EFS" operation. Also look here: http://forum.gsmhosting.com/vbb/f684...-step-1961415/ Unfortunately currently no other solutions for this issue. |
