12-15-2014, 16:49 | #4 (permalink) |
Freak Poster Join Date: Apr 2014
Member: 2170693 Status: Offline Thanks Meter: 1 | for some reason when i try to factory unlock this model. phones isnt reading with octoplus Welcome to Octoplus/Octopus Box Samsung software version 1.7.8 ----------------------------------------------------------------------------------- To connect SM-N910T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Connecting to server... Username: nycboy007-01 Authorizing... Checking balance... Your balance: 91 credits. ----------------------------------------------------------------------------------- Connect phone to UART cable, phone must be ON and screen must be permanently active! Searching for a phone. Please wait... Phone was not found! Factory Unlock operation failed! |
12-15-2014, 18:34 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Block highlighted pin with a tape and try to connect the phone via Samsung Micro UART C3300k/C3303k cable with 523-525kOhm resistor. Last edited by Octopus box; 12-15-2014 at 19:15. |
