04-11-2016, 11:02 | #1 (permalink) |
Freak Poster Join Date: Dec 2014 Location: bahrain
Member: 2308999 Status: Offline Sonork: 100.1657583 Thanks Meter: 34 | SM-N920C FRP lock problem [Solved] Last edited by Octopus box; 04-13-2016 at 11:16. |
04-11-2016, 11:08 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. Try to write "SBOOT_N920C_OJ5" Sboot file from the Support Area as a firmware, then repeat "Reset FRP/Reactivation/EE" operation. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
04-11-2016, 12:10 | #3 (permalink) | |
Member: 2308999 Status: Offline Sonork: 100.1657583 Thanks Meter: 34 | Quote:
04-12-2016, 10:58 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You can download necessary files via "Files Downloader" on "Support & options" tab of the Software: 1. Press "Files Downloader" button in Software. 2. Input "SBOOT_N920C_OJ5" into "Find" field, press "Search" button. 3. Double-click the file, to start a download. |
04-12-2016, 11:56 | #7 (permalink) |
Member: 2308999 Status: Offline Sonork: 100.1657583 Thanks Meter: 34 | http://support.octoplusbox.com:82/su...20C_95_OJ5.oct i got this let me try |
04-13-2016, 08:00 | #8 (permalink) |
Member: 2308999 Status: Offline Sonork: 100.1657583 Thanks Meter: 34 | n920c frp reset done android version 6 Welcome to Octoplus/Octopus Box Samsung software version 2.2.3 ---------------------------------------------------------------------------------- To connect SM-N920C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. Turn on "USB Debugging" option. Selected firmware file: SBOOT_N920C_OJ5.oct Please put the phone into Download Mode and connect USB cable. To put SM-N920C into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Firmware writing successfully completed. Performed by 2.2.3 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N920C To put SM-N920C into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock.. success Resetting EE lock.. success Resetting Samsung Account lock.. success Reset operation completed! Performed by 2.2.3 software version Last edited by askdm7; 04-13-2016 at 08:08. |
The Following User Says Thank You to askdm7 For This Useful Post: |
