11-26-2016, 18:25 | #1 (permalink) |
No Life Poster Join Date: Dec 2012 Location: SRI LANKA
Member: 1857049 Status: Offline Sonork: 100.1627774 Thanks Meter: 208 | Sm-n920l frp done easy mode ----------------------------------------------------------------------------------- To connect SCL24 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-N920L Searching for a phone (waiting for ADB device)... Operation was canceled Performed by 2.4.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-N920L Searching for a phone (waiting for ADB device)... Operation was canceled Performed by 2.4.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-N920L Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-N920L into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Operation was canceled Performed by 2.4.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SM-N920L Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-N920L into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Backup and reset" and make "Factory data reset" Performed by 2.4.5 Software version. Last edited by Octopus box; 11-28-2016 at 08:33. |
The Following 2 Users Say Thank You to samindapowerson For This Useful Post: |
