05-16-2016, 23:32 | #1 (permalink) |
Major Poster Join Date: Jan 2011
Member: 1482229 Status: Offline Thanks Meter: 3 | sm-n920p 6.0.1 unlock with octoplus samsung 2.2.6 version 2.2.6 --------------------------------------------------------------------- -------------- To connect SM-N920P phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. --------------------------------------------------------------------- -------------- Platform: Samsung Android Selected port: COM21 Selected model: SM-N920P Reading info... Phone was not found on the selected port! Reading QCN failed Performed by 2.2.6 software version --------------------------------------------------------------------- -------------- Platform: Samsung Android Selected port: COM21 Selected model: SM-N920P Detected phone model: SM-N920P Firmware compiled date: Thu Mar 31 14:33:23 KST 2016 PDA version: N920PVPS2BPD1 CSC version: N920PSPT2BPD1 SW version: N920PVPS2BPD1 Phone SN: 00000000000 Android version: 6.0.1 (MMB29K) Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: MDM9635M Codename: nobleltespr Checking Root: Phone is Rooted. Reading security backup, please wait... Security read successfully. Performed by 2.2.6 software version --------------------------------------------------------------------- -------------- Platform: Samsung Android Selected port: COM21 Selected model: SM-N920P Detected phone model: SM-N920P Firmware compiled date: Thu Mar 31 14:33:23 KST 2016 PDA version: N920PVPS2BPD1 CSC version: N920PSPT2BPD1 SW version: N920PVPS2BPD1 Phone SN: 00000000000 Android version: 6.0.1 (MMB29K) Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: MDM9635M Codename: nobleltespr Checking Root: Phone is Rooted. Reading EFS, please wait... EFS read successfully. Performed by 2.2.6 software version --------------------------------------------------------------------- -------------- Platform: Samsung Android Selected port: COM21 Selected model: SM-N920P Reading info... Phone was not found on the selected port! Reading QCN failed Performed by 2.2.6 software version --------------------------------------------------------------------- -------------- Platform: Samsung Android Selected port: COM21 Selected model: SM-N920P Detected phone model: SM-N920P Firmware compiled date: Thu Mar 31 14:33:23 KST 2016 PDA version: N920PVPS2BPD1 CSC version: N920PSPT2BPD1 SW version: N920PVPS2BPD1 Phone SN: 00000000000 Android version: 6.0.1 (MMB29K) Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: MDM9635M Codename: nobleltespr Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-N920P-16-05-2016_18-23-12 file Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.6 software version --------------------------------------------------------------------- -------------- Platform: Samsung Android Selected port: COM21 Selected model: SM-N920P Detected phone model: SM-N920P Firmware compiled date: Thu Mar 31 14:33:23 KST 2016 PDA version: N920PVPS2BPD1 CSC version: N920PSPT2BPD1 SW version: N920PVPS2BPD1 Phone SN: 00000000000 Android version: 6.0.1 (MMB29K) Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: MDM9635M Codename: nobleltespr Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-N920P-16-05-2016_18-26-46 file Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.6 software version It showed successful on both attempts but phone acts as not unlocked. I am not sure if I have to enable something in the phone's hidden menu. Can anyone point me to right direction please? |
05-17-2016, 11:05 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please check whether GSM/(E)GPRS/WCDMA GCF is enabled in your phone: 1. Open hidden menu. There are two ways of doing it: 1) Run the following command via ADB: Code: adb shell su -c "am broadcast -a android.provider.Telephony.SECRET_CODE -d android_secret_code://IOTHIDDENMENU" 2) Perform the following actions: 1. Dial *#0011# and in the service menu do the following. 2. Click "Menu" then "Key input" then input Q then press "Ok". 3. Click "Menu" then "Back". 4. Click "Menu" then "Key input" then input 0000 then click "Ok". 2. After these steps Hidden menu should open. In Hidden menu, depending on available options, try to do the following: I.
II.
After these actions go to Settings -> Mobile Networks and Set Network Mode to Automatic, or GSM. |
05-18-2016, 01:49 | #4 (permalink) | |
Member: 1482229 Status: Offline Thanks Meter: 3 | Quote:
1) Run the following command via ADB: Code: adb shell su -c "am broadcast -a android.provider.Telephony.SECRET_CODE -d android_secret_code://IOTHIDDENMENU" 2) Perform the following actions: 1. Dial *#0011# and in the service menu do the following. 2. Click "Menu" then "Key input" then input Q then press "Ok". 3. Click "Menu" then "Back". 4. Click "Menu" then "Key input" then input 0000 then click "Ok". 2. After these steps Hidden menu should open. In Hidden menu, depending on available options, try to do the following: After this I do not have hidden menu. Am I doing something wrong? I followed exactly says on here up to paragraph above. Any idea? | |
05-18-2016, 03:41 | #5 (permalink) | |
However the instruction I and II both does not match. I tried searching around on my own and could not find gcf. Maybe I can put screen shots of the phone tomorrow. | |
05-18-2016, 10:57 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please contact us to Skype, or Yahoo! Messenger, we will try to help You. Our contacts You can find in our profile. |
