06-14-2018, 05:05 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: srilanka
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | SM-N920S DRK fix problem [Answered] ----------------------------------------------------------------------------------- To connect SM-N920S phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-N920S Operation: DRK Fix Warning: Selected model (SM-N920S) differs from the detected one (ZENLTE)! If you want select (ZENLTE) as (SM-N920S) model, please check "manual select". DRK fixing failed! Performed by 2.6.9 Software version. Last edited by Octopus box; 06-14-2018 at 05:39. |
06-14-2018, 05:38 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. As You can see from your Software log, your device was detected as ZENLTE, not as SM-N920S: Quote:
Also please connect the device in normal mode, read phone's info and post it here, we will check it. | |
