01-16-2016, 12:43 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Philippines
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 269 | Sm-N920s FRP reset problem... Sm-N920s, google account problem.. Successful when reset FRP but handset stucked... it doesnt reboot upon finishing reset.. Code: Logs: Welcome to Octoplus/Octopus Box Samsung software version 2.1.7 ----------------------------------------------------------------------------------- To connect SM-N920S phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM26 Selected model: SM-N920S To put SM-N920S into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..success thanks! |
01-16-2016, 13:05 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Problem with removal of FRP lock can be caused by new type of Security. You can try to downgrade version of phone's sboot, then repeat "Reset FRP/Reactivation/EE" operation. |
01-18-2016, 13:05 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to reflash the phone with "N920SKSU1AOH4_N920SSKC1AOH4_SKC_Android_5.1.1 " firmware from the Support Area, then repeat "Reset FRP/Reactivation/EE" operation. Post here result and full Software log of performed operations. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
02-17-2016, 11:46 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | If You have SM-N920S phone - writing of "N920SKSU1AOH4_N920SSKC1AOH4_SKC_Android_5.1.1 " should not cause problems. |
02-17-2016, 12:45 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please post here, or send us in PM full Software log of "Write Firmware" operation. |
02-17-2016, 13:06 | #10 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2532908 Status: Offline Thanks Meter: 1 | i try to post log but i can not becuse i must have 10 posts or something like that when i complete the 10 posts i will post the log here Last edited by Octopus box; 02-17-2016 at 15:03. |
02-17-2016, 15:04 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | You can send us Software log of the operation in Private Messages. |
02-17-2016, 20:46 | #12 (permalink) |
Freak Poster Join Date: Dec 2007 Location: spain (barcelona)
Member: 650246 Status: Offline Thanks Meter: 28 | also having same problem.all process done.but still asking for google account.any solutino.here is log Welcome to Octoplus/Octopus Box Samsung software version 2.2.0 ----------------------------------------------------------------------------------- Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..success Reset operation completed! |
02-18-2016, 12:09 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. Try to reflash the phone with older (by release date) firmware, then repeat "Reset FRP/Reactivation/EE" operation. |
03-10-2016, 05:04 | #15 (permalink) |
Freak Poster Join Date: Dec 2007 Location: indonesia
Member: 658821 Status: Offline Thanks Meter: 12 | Welcome to Octoplus/Octopus Box Samsung software version 2.2.1 ----------------------------------------------------------------------------------- To connect SM-N920S phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: N920SKSU1AOH4_N920SSKC1AOH4 _N920SKSU1AOH4_HOME.oct Please put the phone into Download Mode and connect USB cable. To put SM-N920S into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing Firmware Failed Performed by 2.2.1 software version Please put the phone into Download Mode and connect USB cable. To put SM-N920S into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing Firmware Failed Performed by 2.2.1 software version same problem downgrade, how to solution ???? |
