05-07-2016, 00:40 | #1 (permalink) |
Major Poster Join Date: Jan 2011
Member: 1482229 Status: Offline Thanks Meter: 3 | SM-N920T Cert File Failed [Solved] I am not sure why it won't work. Welcome to Octoplus/Octopus Box Samsung software version 2.2.5 --------------------------------------------------------------------- -------------- To connect SM-N920T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. --------------------------------------------------------------------- -------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-N920T Selected file: C:\Users\FishMarket\Desktop\cert-sm- n920t-a_354035XXXXXXXX_rf8g82h36wm.cert Detected phone model: SM-N920T Firmware compiled date: Sat Sep 19 16:43:04 KST 2015 PDA version: N920TUVU2COI5 CSC version: N920TTMB2COI5 SW version: N920TUVU2COI5 Android version: 5.1.1 (LMY47X) Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Codename: nobleltetmo Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus \Octoplus_Samsung\BACKUP\Security-SM-N920T- Unknown06-05-2016_19-26-45-.asec file Checking Certificate file... Certificate file successfully checked Deactivating MSL... Executing exploit... Exploit has been executed successfully Writing Certificate... Performed by 2.2.5 software version Then it won't do anything. IMEI is still same after manually reboot. Am I doing something wrong? I also intentionally inserted XXXX at cert file for posting. Real operation had real numbers in it. Any advice or help will be appreciated. Last edited by Octopus box; 05-10-2016 at 10:53. Reason: editing title. |
05-07-2016, 11:24 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please remove SIM card from the phone and repeat "Write Cert" operation. If problem will remain, please do the next: 1. Write first Security backup back into the phone. 2. Reflash the phone. 3. Root the phone with CF Auto Root. 4. Repeat "Write Cert" operation. Post here result and full Software log of your actions. |
05-08-2016, 00:41 | #3 (permalink) | |
Member: 1482229 Status: Offline Thanks Meter: 3 | Quote:
I repeated "write Cert" Operation This is the result. Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\07-05-2016_19-00-48.log" created (5/7/2016 7:00:50 PM). INFO : 5/7/2016 7:00:58 PM > Set up system language English (file: English.ini) INFO : 5/7/2016 7:00:58 PM > Welcome to Octoplus/Octopus Box Samsung software version 2.2.5 INFO : 5/7/2016 7:01:03 PM > ----------------------------------------------------------------------------------- INFO : 5/7/2016 7:01:03 PM > To connect SM-N920T phone you have to perform the following steps: INFO : 5/7/2016 7:01:03 PM > 1. Disconnect USB cable from phone. INFO : 5/7/2016 7:01:03 PM > 2. Go to Menu->Settings->More->About Device. INFO : 5/7/2016 7:01:03 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 5/7/2016 7:01:03 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 5/7/2016 7:01:03 PM > 5. Turn on "USB Debugging" option. INFO : 5/7/2016 7:01:08 PM > ----------------------------------------------------------------------------------- INFO : 5/7/2016 7:01:08 PM > Platform: Samsung Android INFO : 5/7/2016 7:01:08 PM > Selected port: COM20 INFO : 5/7/2016 7:01:08 PM > Selected model: SM-N920T INFO : 5/7/2016 7:01:08 PM > Searching for a phone. Please wait... INFO : 5/7/2016 7:01:10 PM > Phone found. INFO : 5/7/2016 7:01:12 PM > Detected phone model: SM-N920T INFO : 5/7/2016 7:01:12 PM > Firmware compiled date: Sat Sep 19 16:43:04 KST 2015 INFO : 5/7/2016 7:01:12 PM > PDA version: N920TUVU2COI5 INFO : 5/7/2016 7:01:12 PM > CSC version: N920TTMB2COI5 INFO : 5/7/2016 7:01:12 PM > SW version: N920TUVU2COI5 INFO : 5/7/2016 7:01:12 PM > Android version: 5.1.1 (LMY47X) INFO : 5/7/2016 7:01:12 PM > Country: USA INFO : 5/7/2016 7:01:12 PM > HW platform: exynos5 INFO : 5/7/2016 7:01:12 PM > HW Chip: exynos7420 INFO : 5/7/2016 7:01:12 PM > HW Modem: SHANNON333 INFO : 5/7/2016 7:01:12 PM > Codename: nobleltetmo INFO : 5/7/2016 7:01:12 PM > Performed by 2.2.5 software version INFO : 5/7/2016 7:01:18 PM > ----------------------------------------------------------------------------------- INFO : 5/7/2016 7:01:19 PM > Platform: Samsung Android INFO : 5/7/2016 7:01:19 PM > Selected port: COM20 INFO : 5/7/2016 7:01:19 PM > Selected model: SM-N920T INFO : 5/7/2016 7:01:24 PM > Selected file: C:\Users\FishMarket\Desktop\cert-sm-n920t-a_354035070103799_rf8g82h36wm.cert INFO : 5/7/2016 7:01:26 PM > Detected phone model: SM-N920T INFO : 5/7/2016 7:01:26 PM > Firmware compiled date: Sat Sep 19 16:43:04 KST 2015 INFO : 5/7/2016 7:01:26 PM > PDA version: N920TUVU2COI5 INFO : 5/7/2016 7:01:26 PM > CSC version: N920TTMB2COI5 INFO : 5/7/2016 7:01:26 PM > SW version: N920TUVU2COI5 INFO : 5/7/2016 7:01:26 PM > Android version: 5.1.1 (LMY47X) INFO : 5/7/2016 7:01:26 PM > Country: USA INFO : 5/7/2016 7:01:27 PM > HW platform: exynos5 INFO : 5/7/2016 7:01:27 PM > HW Chip: exynos7420 INFO : 5/7/2016 7:01:27 PM > HW Modem: SHANNON333 INFO : 5/7/2016 7:01:27 PM > Codename: nobleltetmo INFO : 5/7/2016 7:01:27 PM > Checking Root: INFO : 5/7/2016 7:01:27 PM > Phone is Rooted. INFO : 5/7/2016 7:01:27 PM > Reading security backup, please wait... INFO : 5/7/2016 7:02:01 PM > Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N920T-Unknown07-05-2016_19-01-24-.asec file INFO : 5/7/2016 7:02:01 PM > Checking Certificate file... INFO : 5/7/2016 7:02:01 PM > Certificate file successfully checked INFO : 5/7/2016 7:02:08 PM > Deactivating MSL... INFO : 5/7/2016 7:02:18 PM > Executing exploit... INFO : 5/7/2016 7:04:01 PM > Exploit has been executed successfully INFO : 5/7/2016 7:04:01 PM > Writing Certificate... ERROR : 5/7/2016 7:04:11 PM > Writing Certificate failed INFO : 5/7/2016 7:04:14 PM > Performed by 2.2.5 software version Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\07-05-2016_19-00-48.log" closed (5/7/2016 7:06: This time at least writing certificate actually tried to write then failed. I am not sure if error is coming from there are no serial number or IMEI on the phone now. Any idea how to get the phone back to original state without backup file? Or am I just SOL? | |
05-09-2016, 10:15 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please upload the following files to any file-sharing service: 1. First Security backup of the phone, which You have. 2. *.log and *.logx files of performed operations. Post here download link for these files and we will check what causes the problem. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. You can write the very first Security backup of the phone, which You have, to restore the phone to its initial condition. |
05-10-2016, 04:46 | #5 (permalink) | |
