04-15-2016, 17:19 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Italy Age: 42
Member: 164613 Status: Offline Thanks Meter: 11 | SM-P605v Verizon unlock Is it possible to unlock the Samsung Galaxy Note 10.1 SM-P605v by Verizon? Mine is on 5.1.1 I tried to follow the instructions but unfortunately there is no dialling function in the device, and even in the recovery menu there is no possibility to change the connectivity settings Thanks in advance, Roman |
04-15-2016, 17:38 | #3 (permalink) |
Member: 164613 Status: Offline Thanks Meter: 11 | On mine, there is a message "SIM card is not from Verizon Wireless", there is the "3G" mark near the antenna symbol, but can not connect to the internet. So I think it's locked. |
04-15-2016, 17:52 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Try to enter exactly the next in Calculator: (+30012012732+ . Check whether Dialer appears after this. |
04-15-2016, 18:41 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to reflash the tab. Check whether Dialer will be available, or whether it could be enabled by "trick" from previous and try to access Diag Config menu from it (*#0808# / *#7284#). |
04-15-2016, 20:29 | #8 (permalink) |
Member: 164613 Status: Offline Thanks Meter: 11 | Can I downgrade the tab? At the moment there's 5.1.1, vhat version would you recomment to downgrade without losing IMEI? Thx! P.S. Should I choose a Verizon firmware or I can install other brand/ unbranded version? Is the model 605v compatible with other models/letters? |
04-16-2016, 12:01 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We recommend not to downgrade firmware version of the tab. Downgrading can damage the device. Android 5.1.1 firmware for SM-P605V is available in the Support Area. |
04-16-2016, 14:40 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please check the Support Area again, or search for "P605VVRUDOH2_P605VVZWDOH2_VZW_Android_5.1.1" in Files Downloader (can be opened by pressing "Files Downloader" button from "Support & options" tab of the Software. |
04-16-2016, 16:37 | #13 (permalink) |
Member: 164613 Status: Offline Thanks Meter: 11 | I flashed the tab with the FW downloaded from Support (2Gb instead of 1,5Gb of FW downloadable for Odin), there still is no dial tab on the menu. I dialled the "magic" code to get into Factory Mode, tried to dial all possible combinations but no response... Even for *#06# Then, I noticed that going to the "Android/ EFS Manager" of the suite I can read the tab info Platform: Samsung Android Selected port: COM1 Selected model: SM-P605V Reading info, please wait... ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-P605V Firmware compiled date: Mon Aug 31 23:48:34 KST 2015 PDA version: P605VVRUDOH2 CSC version: P605VVZWDOH2 SW version: P605VVRUDOH2 Phone SN: 00000000000 Android version: 5.1.1 (LMY47X) Country: USA HW platform: msm8974 HW Chip: MSM8974 HW Modem: MSM8974 Codename: lt03ltevzw Performed by 2.2.4 software version but going to the Main tab i can't read the info Platform: Samsung Android Selected port: COM1 Selected model: SM-P605V Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM6 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.2.4 software version Can you explain why does this thing succeed please? |
04-16-2016, 17:11 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You managed to read tab's info via ADB, but can Software can't communicate with it via diagnostic port. Try to make "Enable DIAG", then try to read tab's info from "Main" tab of the Software. |
