10-28-2014, 16:11 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | sm-t217a 4.4.2 how unlock it ----------------------------------------------------------------------------------- To connect SM-T217A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to Calculator application. Enter "(+30012012732+" number, to get phone dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM36 Selected model: SM-T217A Mode: Normal Phone model: SM-T217A Firmware compiled date: May 20 2014 Firmware compiled time: 01:00:00 Firmware released date: Sep 4 2014 Firmware released time: 16:49:26 Phone IMEI: 359163-05-309696-5 SW version: M8930B-AAAATAZM-5.0.060198 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM36 Selected model: SM-T217A Mode: Normal Phone model: SM-T217A Firmware compiled date: May 20 2014 Firmware compiled time: 01:00:00 Firmware released date: Sep 4 2014 Firmware released time: 16:49:26 Phone IMEI: 359163-05-309696-5 SW version: M8930B-AAAATAZM-5.0.060198 Unlocking phone... Creating NVM backup Reading NVM done! Firmware compiled date: Thu Sep 4 16:09:27 KST 2014 PDA version: T217AUCUBNI1 CSC version: T217AATTBNI1 SW version: T217AUCUBNI1 Phone IMEI: 359163053096965 Phone SN: RF2F30FPC0V Android version: 4.4.2 (KOT49H) Cheking Root Can't root Android version 4.4.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Phone unlocking failed i cant find root file this it cant be rooted v root r kingo root |
The Following User Says Thank You to CHAUDHRAY ARSHAD For This Useful Post: |
10-29-2014, 06:17 | #4 (permalink) | ||
Member: 328688 Status: Offline Thanks Meter: 2,282 | Quote:
Quote: Android version: 4.2.2 (JDQ39) my one 4.4.2 open eyes be4 u reply it | ||
10-30-2014, 08:56 | #6 (permalink) |
Member: 328688 Status: Offline Thanks Meter: 2,282 | i flash tht file on support still it stock pleaz upload 4.4.2 Welcome to Octoplus/Octopus Box Samsung software version 1.7.3 ----------------------------------------------------------------------------------- To connect SM-T217A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to Calculator application. Enter "(+30012012732+" number, to get phone dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: T217AUCUAMHC_T217AATTAMHC_ATT_USA (AT&T)_Android_4.2.2.oct Please put the phone into Download Mode and connect USB cable. To put SM-T217A into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. |
10-30-2014, 09:09 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | We will try to find 4.4.2 Android firmware and upload it into the Support Area. |
02-06-2015, 07:49 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Try to use the latest versions of VRoot, Kingo Root, IRoot, Cydia Impactor Softwares. Also try to use TowelRoot. |
05-14-2015, 16:02 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Unfortunately we don't have other rooting Softwares/exploits for SM-T217A. Last edited by Octopus box; 05-14-2015 at 16:31. |
