09-01-2015, 05:18 | #1 (permalink) |
Freak Poster Join Date: Feb 2011 Location: bannu
Member: 1508215 Status: Offline Thanks Meter: 47 | sm-t217s unlock done but steel locked ----------------------------------------------------------------------------------- To connect GT-I8190 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "PDA" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-T217S phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to Calculator application. Enter "(+30012012732+" number, to get phone dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-T217S Reading info, please wait... Detected phone model: SM-T217S Firmware compiled date: Wed Aug 21 23:22:55 KST 2013 PDA version: T217SVPUAMH9 CSC version: T217SSPTAMH9 SW version: T217SVPUAMH9 Phone IMEI: 99000436926405 Phone SN: 00000000000 Android version: 4.2.2 (JDQ39) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-T217S Reading info... Phone was not found on the selected port! Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-T217S Reading info, please wait... Detected phone model: SM-T217S Firmware compiled date: Wed Aug 21 23:22:55 KST 2013 PDA version: T217SVPUAMH9 CSC version: T217SSPTAMH9 SW version: T217SVPUAMH9 Phone IMEI: 99000436926405 Phone SN: 00000000000 Android version: 4.2.2 (JDQ39) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-T217S Reading info... Mode: Normal Firmware compiled date: Aug 04 2013 Firmware compiled time: T217S.0 Firmware released date: Aug 22 2013 Firmware released time: 00:15:43 SW Version: M8930B-AAAATAZM-5.0.060109 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: SM-T217S Reading info... Mode: Normal Firmware compiled date: Aug 04 2013 Firmware compiled time: T217S.0 Firmware released date: Aug 22 2013 Firmware released time: 00:15:43 SW Version: M8930B-AAAATAZM-5.0.060109 Detected phone model: SM-T217S Firmware compiled date: Wed Aug 21 23:22:55 KST 2013 PDA version: T217SVPUAMH9 CSC version: T217SSPTAMH9 SW version: T217SVPUAMH9 Phone IMEI: 99000436926405 Phone SN: 00000000000 Android version: 4.2.2 (JDQ39) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-T217S-01-09-2015_09-12-24 file Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. |
