06-28-2017, 07:15 | #1 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2151826 Status: Offline Thanks Meter: 5 | SM-T377A Google Account Removal with Octoplus ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-T377T Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.5.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-T377T Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.5.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-T377T To put SM-T377T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.5.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-J120F Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.5.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-J120F Reset FRP/ Reactivation lock operation for SM-J120F will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J120F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.5.5 Software version. Last edited by Octopus box; 06-28-2017 at 07:31. |
The Following 5 Users Say Thank You to akgranpa For This Useful Post: |
