12-20-2014, 17:53 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Currently we don't have cert files for SM-T705. However, You can read certificate from correctly working SM-T705 via "Read Cert" button and use it. |
12-21-2014, 04:39 | #4 (permalink) |
Major Poster Join Date: Oct 2011 Age: 29
Member: 1679179 Status: Offline Thanks Meter: 10 | Okay Thanks is it same for all models? If i have other T705 same model then if i do read cert then i can write same cert on my tab which not works, it will work then? Thanks |
12-21-2014, 09:39 | #5 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Quote:
12-22-2014, 14:31 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | What about phone's baseband? Please read out phone's info via ADB (turn on USB Debugging Mode in the phone and press "Read info" button at "Android / EFS manager" tab in the Softwrae) and post here full Software log with this info. |
12-23-2014, 09:35 | #8 (permalink) | |
Member: 1679179 Status: Offline Thanks Meter: 10 | Quote:
i flashed my tab with new firm.. and now imei is not null but the problem is no network now. Thanks | |
12-23-2014, 10:03 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to find and write IMEI Certificate from another SM-T705 and write it into your device, maybe, IMEI in your device is in the black list of your network operator. Also, try to make "Unlock", maybe, your device is locked. |
02-19-2015, 13:43 | #13 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2346019 Status: Offline Thanks Meter: 1 | hey i can give you one certificate but its not working in the UK , if you use it outside Uk i can give it to you. dont worry its free! Last edited by stockexchange; 02-19-2015 at 13:49. |
02-19-2015, 13:48 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | All Certificates files, which we have, are present in the Support Area (press "Go to Support" button at "Support & Options" tab in the Software) in the folder "Samsung/FOR UNLOCK ANDREPAIR/Certificates/". |
