10-28-2013, 18:40 | #1 (permalink) |
Freak Poster Join Date: Feb 2012 Location: pakistan Age: 30
Member: 1724706 Status: Offline Sonork: 100.1622356 Thanks Meter: 63 | Sph-L720 Sprint s4 unlock problem Platform: Samsung Anycall Selected port: COM80 Selected model: SPH-L720 Mode: Normal Phone model: SPH-L720 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW Version: Unlocking phone... Phone unlocking failed |
10-29-2013, 08:00 | #2 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. As You can see from the Software log, You have not connected the phone correctly. Try to connect the phone via Micro USB and via Samsung Micro UART cables as it is written in Software manual: Quote:
04-17-2014, 13:15 | #3 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Sph-L720 Sprint s4 unlock problem also. 4.3 Baseband L720VPUEMK2 Quote:
Sph-L720 Sprint s4 unlock problem ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM94 Selected model: SPH-L720 Mode: Normal Phone model: SPH-L720 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW Version: Unlocking phone... Phone unlocking failed To connect SPH-L720 phone via Micro USB cable, you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes" 5. Go to dial window 6. Enter "*#0808#" number. 7. Set "USB" radio button to "MODEM" value (Not have this option) 8. Go to "Qualcomm USB Settings" (Not have this option) 9. Select "DM+Modem+ADB". (Only This option highlight when dial "*#0808#" ) 10. Close window. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "[1]DM/DUM over HS-USB" value. did 14. Restart phone. 15. Press "Read Info" in software. but same problem. help Octopus Box Support. Thanks in advance | |
04-17-2014, 13:20 | #4 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
04-17-2014, 14:02 | #5 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Thanks for reply. Can I downgrade from 4.3 to 4.2.2 MDL firmware? or can u give me MDL firmware for downgrade tested? I tried MDC 4.2.2 from support but said Kernel not Samsung Authorized. Any solution? |
