Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2007
Member: 621334 Status: Offline Thanks: 148
| Sph m8400 unlocked ,, but still lock. TRY TO UNLOCK SPH-M8400 SHOW ,,, UNLOCKED BUT STILL LOCK ![]() TRY TO THE SETTING CARD WITH MOTO OR BLACKBERY ,,, STILL SAME ![]() THIS THE RESULT ... Welcome to Octopus Box Samsung software version 1.3.6 ----------------------------------------------------------------------------------- To connect SPH-M8400 phone you have to perform the following steps: 1. Go to dial window. 2. Enter "*#9090#" number. 3. Open numerical keyboard and press "1" number. 4. "UART_HFK USB_Diag Change complete" message must appear. 5. Press "END" softbutton. 6. go to "MENU" - "SETTINGS" 7. In upper menu select symbol with arrows 8.In oppened connections menu select "USB" 9. If "Active Sync" is checked dissable it 10. Check "Phone" and press left lower softbutton 11. Restart phone. 12. Press "Read Info" in Octopus Samsung software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM15 Selected model: SPH-M8400 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM15 Selected model: SPH-M8400 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Selected firmware file: SPH_M8400_21898_Unlocked.oct To put SPH-M8400 phone into emergensy mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold Call" +"Menu"+"Power ON" buttons. 3. Insert usb cable. Searching for phone. Please wait... Phone successfully connected Firmware write started. Writing PDA section... Updating data, plaese wait... Updating data successfully completed. Continue writing PDA section... Updating data, plaese wait... Updating data successfully completed. PDA section has been written successfully. Writing PHONE section... Updating data, plaese wait... Updating data successfully completed. PHONE section has been written successfully. Firmware writing successfully completed. |
| | #2 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Oct 2009
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks: 3,596
| Hello. What is written in phones screen when You insert SIM card? Please make photo of phone's screen and post it here. What SIM card do You use? Have You tried with different SIM cards? |
| | #5 (permalink) | |
| Quote:
ImageShack® - Online Photo and Video Hosting | |
| | #6 (permalink) | |
| Quote:
| | #10 (permalink) |
| this the result ,,, thanks Welcome to Octopus Box Samsung software version 1.3.7 ----------------------------------------------------------------------------------- To connect SPH-M8400 phone you have to perform the following steps: 1. Go to dial window. 2. Enter "*#9090#" number. 3. Open numerical keyboard and press "1" number. 4. "UART_HFK USB_Diag Change complete" message must appear. 5. Press "END" softbutton. 6. go to "MENU" - "SETTINGS" 7. In upper menu select symbol with arrows 8.In oppened connections menu select "USB" 9. If "Active Sync" is checked dissable it 10. Check "Phone" and press left lower softbutton 11. Restart phone. 12. Press "Read Info" in Octopus Samsung software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM15 Selected model: SPH-M8400 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM15 Selected model: SPH-M8400 Mode: Emergency NVM can’t be repaired for SPH-M8400 phone in emergency mode ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM15 Selected model: SPH-M8400 Mode: Emergency NVM can’t be repaired for SPH-M8400 phone in emergency mode ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM15 Selected model: SPH-M8400 Mode: Emergency NVM can’t be repaired for SPH-M8400 phone in emergency mode ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM15 Selected model: SPH-M8400 Mode: Emergency NVM can’t be repaired for SPH-M8400 phone in emergency mode Selected firmware file: SPH_M8400_21898_Unlocked.oct ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM15 Selected model: SPH-M8400 Mode: Emergency NVM can’t be repaired for SPH-M8400 phone in emergency mode To put SPH-M8400 phone into emergensy mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold Call" +"Menu"+"Power ON" buttons. 3. Insert usb cable. Searching for phone. Please wait... Phone successfully connected Firmware write started. Writing PDA section... Updating data, plaese wait... Updating data successfully completed. Continue writing PDA section... Updating data, plaese wait... Updating data successfully completed. PDA section has been written successfully. Writing PHONE section... Updating data, plaese wait... Updating data successfully completed. PHONE section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM15 Selected model: SPH-M8400 Mode: Emergency NVM can’t be repaired for SPH-M8400 phone in emergency mode ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM15 Selected model: SPH-M8400 Mode: Emergency NVM can’t be repaired for SPH-M8400 phone in emergency mode ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM15 Selected model: SPH-M8400 Mode: Emergency NVM can’t be repaired for SPH-M8400 phone in emergency mode need the real solution ,,, thanks. |
| | #11 (permalink) |
| Why You connect the phone in Emergency Mode? Please connect it in Normal Mode! Or in your phone the User (phone) code is set? Note! If in your phone the User (Phone) code is set, you can't connect the phone in Normal Mode! Also Octopus Samsung software doesn't support resetting (reading) User code for this phone model. |
| | #13 (permalink) | |
| Quote:
| | #14 (permalink) |
| If in your phone the User (Phone) code is set, you can't connect the phone in Normal Mode, so it is not possible to make Repair NVM. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 05-10-2012 14:14 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 11 | 06-26-1999 06:22 |
| Need info for unliocking 2 lock (with pic microprocesors) | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 06-26-1999 01:00 |
