04-03-2012, 05:06 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: INDIA
Member: 130050 Status: Offline Thanks Meter: 83 | Help Me Octopus Team !!!!!!!!! [Solved] 1st : After Blink i have flash in Odin with : T499UVKE4-T499UVKE4-T499UVKE4-HOME But SAME PROB. 2nd : i Repair Boot in RIFF box ( Before repair boot my phone already goes in Download mode ) then i flash with again : T499UVKE4-T499UVKE4-T499UVKE4-HOME , but SAME PROBLEM 3rd : i read this post : http://forum.gsmhosting.com/vbb/f664...a-but-1449343/ , Then i decide and purchase New " Octopus Samsung ".... 4th : i flashe phone in Octopus Sam with this FW : T499UVKE4-T499UVKE4-T499UVKE4.oct Then Try with SGH-T499V_SW_KG23.oct But No Luck Same Prob Then i try with SGH-T499Y_95_SW_95_SKG2.oct BUT SAME PROB........ SO PLEASE ADVICE ME OCTOPUS TEAM AND PLS ALIVE MY PHONE AGAIN IN WORKING CON..... THAX IN ADV. Cont :- ICQ : 619329104 & sonork : 100.1605386 Last edited by Octopus box; 04-09-2012 at 08:26. |
04-03-2012, 05:57 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Try to do the next: 1. Make Erase Full flash with any Jtag tool You have and Repair the phone. 2. Re-flash the phone with Octops Box Samsung software with "T499UVKE4-T499UVKE4-T499UVKE4.oct" firmware from the support area. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
04-03-2012, 07:17 | #6 (permalink) |
Member: 130050 Status: Offline Thanks Meter: 83 | hello sir , Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Erasing FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF...OK WARNING: Erasing Error (0x24) at 0x00000FBC0000 is Ignored. Erase continues. WARNING: Erasing Error (0x24) at 0x00000FCC0000 is Ignored. Erase continues. WARNING: Erasing Error (0x24) at 0x00001EA00000 is Ignored. Erase continues. WARNING: Erasing Error (0x24) at 0x00001EE00000 is Ignored. Erase continues. Completed in 00:00:12.777 (Average Transfer Rate: 41033.73 kB/s) Repai Boot ::: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.31, JTAG Manager Version: 1.41 Selected Resurrector: [Samsung T499 V1.0.4449.56799] Connecting to the dead body...OK Detected dead body ID: 0x203C00E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Selected Resurrection Data for the NAND Chip with Page size = 4KB Flashing the dead body...OK Resurrection complete! after that i flash with octopus but same result phone blinking........... |
04-03-2012, 07:21 | #7 (permalink) |
Member: 130050 Status: Offline Thanks Meter: 83 | To connect SGH-T499 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in Octopus Samsung software. Selected firmware file: T499UVKE4-T499UVKE4-T499UVKE4.oct Please put your phone in download mode and connect to PC. To put SGH-T499 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume-" +"Power" buttons. Searching for phone. Please wait... Found phone on Firmware write started. Writing amss section... amss section has been written successfully. Writing boot.img section... boot.img section has been written successfully. Writing recovery.img section... recovery.img section has been written successfully. Writing system.rfs section... system.rfs section has been written successfully. Writing csc.rfs section... csc.rfs section has been written successfully. Please, restart phone to apply changes Firmware writing successfully completed. BUT PHONE STILL BLINKING............... |
04-03-2012, 07:51 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | As I see from the log abow - there are some errors during of erasing... Try to perform these operations using Medusa Box. |
04-03-2012, 07:57 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | There is no another solution - need to erase full flash and repair the phone correctly. |
04-09-2012, 07:56 | #11 (permalink) |
Member: 130050 Status: Offline Thanks Meter: 83 | Yes Yes Yes, Thank you Medusa & Octopus Samsung, My T499 Alive again and working GOOD Now by Repair in 1st Medusa & Then Reflash in Octopus Samsung..... Thanks Medusa & Octopus Samsung For Gr8 Work And Offcourse Gr8 Suppt..... |
The Following User Says Thank You to Devashish Mobile For This Useful Post: |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
