02-16-2015, 15:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In a point from Universe! Age: 40
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | Strange problem with s5 mini g800f [Solved] I've encountered a very strange problem with this phone on Saturday; I had 6 g800f to unlock and all was fine without problems. Last unlocked phone the customer took it and went home. Over the night, the original IMEI was changed to a nokia 6310 IMEI. The IMEI from the phone is this 350695200123951 and you can see that is from a Nokia 6310. Here is a complet log for that phone: Code: NFO : 14.02.2015 11:09:58 > Platform: Samsung Android INFO : 14.02.2015 11:09:58 > Selected port: COM1 INFO : 14.02.2015 11:09:58 > Selected model: SM-G800F WARN : 14.02.2015 11:09:59 > Please, press "OK" button on the phone to allow USB debugging.. INFO : 14.02.2015 11:10:00 > Detected phone model: SM-G800F INFO : 14.02.2015 11:10:00 > Firmware compiled date: Wed Aug 27 00:14:59 KST 2014 INFO : 14.02.2015 11:10:01 > PDA version: G800FXXU1ANH2 INFO : 14.02.2015 11:10:02 > CSC version: G800FORO1ANG3 INFO : 14.02.2015 11:10:02 > SW version: G800FXXU1ANH6 INFO : 14.02.2015 11:10:03 > Phone IMEI: 352960000000000 INFO : 14.02.2015 11:10:04 > Phone SN: RF8FA0M0FPH INFO : 14.02.2015 11:10:04 > Android version: 4.4.2 (KOT49H) INFO : 14.02.2015 11:10:04 > Checking Root: ERROR : 14.02.2015 11:10:13 > Phone unlocking failed INFO : 14.02.2015 11:10:48 > ----------------------------------------------------------------------------------- INFO : 14.02.2015 11:10:49 > Platform: Samsung Android INFO : 14.02.2015 11:10:49 > Selected port: COM1 INFO : 14.02.2015 11:10:49 > Selected model: SM-G800F WARN : 14.02.2015 11:10:49 > Please, press "OK" button on the phone to allow USB debugging.. ERROR : 14.02.2015 11:10:49 > Proper android device not found. Make shure that "USB debug" option on the device is turned on. ERROR : 14.02.2015 11:10:49 > Phone unlocking failed INFO : 14.02.2015 11:10:53 > ----------------------------------------------------------------------------------- INFO : 14.02.2015 11:10:53 > Platform: Samsung Android INFO : 14.02.2015 11:10:53 > Selected port: COM1 INFO : 14.02.2015 11:10:53 > Selected model: SM-G800F WARN : 14.02.2015 11:10:53 > Please, press "OK" button on the phone to allow USB debugging.. ERROR : 14.02.2015 11:10:53 > Proper android device not found. Make shure that "USB debug" option on the device is turned on. ERROR : 14.02.2015 11:10:53 > Phone unlocking failed INFO : 14.02.2015 11:11:08 > ----------------------------------------------------------------------------------- INFO : 14.02.2015 11:11:10 > Platform: Samsung Android INFO : 14.02.2015 11:11:10 > Selected port: COM1 INFO : 14.02.2015 11:11:10 > Selected model: SM-G800F INFO : 14.02.2015 11:11:10 > Detected phone model: SM-G800F INFO : 14.02.2015 11:11:10 > Firmware compiled date: Wed Aug 27 00:14:59 KST 2014 INFO : 14.02.2015 11:11:11 > PDA version: G800FXXU1ANH2 INFO : 14.02.2015 11:11:11 > CSC version: G800FORO1ANG3 INFO : 14.02.2015 11:11:12 > SW version: G800FXXU1ANH6 INFO : 14.02.2015 11:11:13 > Phone IMEI: 352960000000000 INFO : 14.02.2015 11:11:14 > Phone SN: RF8FA0M0FPH INFO : 14.02.2015 11:11:14 > Android version: 4.4.2 (KOT49H) INFO : 14.02.2015 11:11:14 > Checking Root: INFO : 14.02.2015 11:11:14 > Phone is Rooted. INFO : 14.02.2015 11:11:14 > Reading security backup, please wait... INFO : 14.02.2015 11:11:47 > Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G800F-Unknown14-02-2015_11-11-10-.asec file INFO : 14.02.2015 11:11:47 > Unlocking phone. This can take some time. Please wait... WARN : 14.02.2015 11:12:10 > Phone will restart now. Please don't disconnect cable! INFO : 14.02.2015 11:12:10 > Phone is successfully unlocked WARN : 14.02.2015 11:12:10 > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) I tried to write back the security backup file but the program is closing by itself. What explanation is for that problem? Thanks! Last edited by Octopus box; 02-16-2015 at 16:40. |
02-16-2015, 15:14 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If You want to write Security backup, do the next: 1. Install the latest Software version (Software). 2. Make Factory data reset and wipe cache partition. 3. Re-flash the phone. 4. Root the phone. 5. Write the first Security backup. 6. Post here full Software log with all of these actions. |
02-16-2015, 16:33 | #3 (permalink) | |
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | Quote:
the security backup without problems now. The original IMEI is back in the phone and unlocked it again. The phone is working fine right now. Code: Welcome to Octoplus/Octopus Box Samsung software version 1.8.4 ----------------------------------------------------------------------------------- To connect SGH-T959V phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G800F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G800F Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G800F Firmware compiled date: Wed Aug 27 00:14:59 KST 2014 PDA version: G800FXXU1ANH2 CSC version: G800FORO1ANG3 SW version: G800FXXU1ANH6 Phone IMEI: 350695200123951 (this is old nokia IMEI) Phone SN: RF8FA0M0FPH Android version: 4.4.2 (KOT49H) Writing security backup, please wait... Phone will restart now. Please don't disconnect cable! Security write successfully. Thanks! | |
02-16-2015, 16:39 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | This is really strange. Most likely, your customer tried to write another IMEI Certificate and hasn't said to You about this. |
02-20-2015, 17:08 | #5 (permalink) |
Junior Member Join Date: Mar 2002 Location: russia, spb Age: 45
Member: 9881 Status: Offline Thanks Meter: 0 | i have same problem, and same imei 350695200123951, but i don't have backup, because i didn't make unlock... how to solve this problem? octoplus samsung software 1.8.5 can not write certificate |
02-20-2015, 17:21 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please contact us on Monday, we will look remotely where can be the problem with your device. |
02-23-2015, 08:10 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Contact us to Skype, Yahoo! Messemger or ICQ, we will try to research the problem with your device. Our contacts You can find in our profile. |
06-30-2015, 17:39 | #10 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1648286 Status: Offline Thanks Meter: 0 | this error is also happening with z3x box. redirecting imei to an old nokia model.. even when your phone is unlocked and you try to write your own imei wont fix it that error.. so here's the solution for SM G800F for the ones that dont have a backup and want to have it back as new. you can write cert from another user backup . then efs. and it will be locked again. to write imei , just select model i9192 . it will appear a window that could be damaged your phone . go ahead and type your original imei on the back of the sticker and you have it now like at beggining, if you need the files . show me how to upload it and i will send it to u. |
