07-29-2014, 16:24 | #1 (permalink) |
No Life Poster Join Date: Mar 2013
Member: 1900730 Status: Offline Thanks Meter: 188 | Support GT-i8260E Code: Plataforma: Samsung Anycall Puerto seleccionado: COM18 Modelo seleccionado: GT-I8260 Reading info, please wait... ADB server killed. Warning: Selected model (GT-I8260) differs from the detected one (GT-I8260E)! If you want select (GT-I8260E) as (GT-I8260) model, please check "manual select". have some changes there? |
07-29-2014, 16:31 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | As You can see, this device is currently not supported. Which actions do You want to perform with the phone exactly? |
07-29-2014, 16:40 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Try to select GT-I8260, check "Manual select" option in the Software and try to connect the phone. Then post here full Software log with phone's info. |
07-29-2014, 17:02 | #5 (permalink) |
Member: 1900730 Status: Offline Thanks Meter: 188 | Manual Select Code: Bienvenido en Octoplus/Octopus Box Samsung software versión 1.6.2 ----------------------------------------------------------------------------------- To connect GT-I8260 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM17 Modelo seleccionado: GT-I8260 Reading info, please wait... Warning: Selected model (GT-I8260) differs from the detected one (GT- I8260E)! If you want select (GT-I8260E) as (GT-I8260) model, please check "manual select". ----------------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM17 Modelo seleccionado: GT-I8260 Reading info, please wait... Modelo del teléfono detectado: GT-I8260E Fecha de creación del firmware: Thu Nov 14 22:14:19 KST 2013 PDA version: I8260EUHAMK3 CSC version: I8260ECHEAMK3 Versión del SW: I8260EUHAMK3 IMEI del teléfono: 359827050199267 Phone SN: RV1F5359LFB Android version: 4.1.2 (JZO54K) |
07-29-2014, 17:21 | #7 (permalink) | |
Member: 1900730 Status: Offline Thanks Meter: 188 | i think need a custom firmware for repair IMEI Quote:
07-29-2014, 17:26 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Quote:
07-29-2014, 17:30 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Have You installed SU manually via SD card? If not, please install. If You can't find SU app for this phone, we will prepare tomorrow the special firmware for Repair IMEI. |
07-29-2014, 17:39 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Try to root the device by using the latest version of VRoot Software, then install SU and run it from phone's menu manually and repeat the "Repair IMEI" operation again. Then post here full Software log. |
07-29-2014, 17:44 | #13 (permalink) | ||
Member: 1900730 Status: Offline Thanks Meter: 188 | Quote:
07-29-2014, 17:49 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | ok . tomorrow we will prepare the special firmware to You for test and contact You. |
07-30-2014, 13:10 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Please contact us to Sonork, ICQ, Skype or Yahoo! Messenger, our contacts You can find in our profile. |
