Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 04-08-2015, 01:39   #1 (permalink)
firultd's Avatar
Member: 1929246
Thanks Meter: 36
Thumbs up Supporter help cant flash gt-i8200L [Solved]
i have downloaded this file from support I8200LUBUANC4_I8200LUUBANC2_TTT_Trinidad_Tobago_An droid_4.2.2.oct but box says file was created for another phone model, what happens?
Old 04-08-2015, 06:19   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,405
Hello.
We will check this firmware and say You the result. Now try to select GT-I8200 (not GT-I8200L) in the Software list and try to write this firmware, maybe, this firmware for converted how for GT-I8200.
Old 04-08-2015, 15:03   #3 (permalink)
firultd's Avatar
Member: 1929246
Thanks Meter: 36
Nope tried every i8200 variants and get same error. Please help need flash this phone or give and Odin flash file to convert.
Old 04-08-2015, 15:12   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
We have re-converted firmware and re-uploaded it into the Support Area. Please re-download this firmware again and try to write. Post here Software log with "Write Firmware" procedure.
Old 04-08-2015, 15:48   #5 (permalink)
firultd's Avatar
Member: 1929246
Thanks Meter: 36
Ok will post when try
Old 04-08-2015, 16:59   #6 (permalink)
firultd's Avatar
Member: 1929246
Thanks Meter: 36
Process done wiht right model, thaks support.
Bienvenido en Octoplus/Octopus Box Samsung software versión 1.9.0
To connect GT-I8200L phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
Seleccione el archivo de firmware: I8200LUBUANC4_I8200LUUBANC2
_TTT_Trinidad_Tobago_Android_4.2.2.oct
Please put the phone into Download Mode and connect USB cable.
To put GT-I8200L into Download Mode, You have to perform the
following steps:
1. Reconnect the battery.
2. Press and hold "Volume-" +"Power"+''Home" keys.
Found phone on
Firmware write started.
Escribiendo la sección TIMH...
L a sección TIMH ha sido escrita con éxito
Escribiendo la sección OBM...
L a sección OBM ha sido escrita con éxito
Escribiendo la sección DTim.Recovery...
L a sección DTim.Recovery ha sido escrita con éxito
Escribiendo la sección LOKE_2ND...
L a sección LOKE_2ND ha sido escrita con éxito
Escribiendo la sección DTim.Primary...
L a sección DTim.Primary ha sido escrita con éxito
Escribiendo la sección LOKE_1ST...
L a sección LOKE_1ST ha sido escrita con éxito
Escribiendo la sección PARAM...
L a sección PARAM ha sido escrita con éxito
Escribiendo la sección KERNEL...
L a sección KERNEL ha sido escrita con éxito
Escribiendo la sección RECOVERY...
L a sección RECOVERY ha sido escrita con éxito
Escribiendo la sección SYSTEM...
L a sección SYSTEM ha sido escrita con éxito
Escribiendo la sección MODEM...
L a sección MODEM ha sido escrita con éxito
Escribiendo la sección CACHE...
L a sección CACHE ha sido escrita con éxito
Escribiendo la sección HIDDEN...
L a sección HIDDEN ha sido escrita con éxito
La escritura del firmware ha sido completada con éxito
Page generated in 0.15779 seconds with 8 queries
