01-29-2016, 08:15 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | T399N after unlock Searching only 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-T399 Detected phone model: SGH-T399 Firmware compiled date: Thu Sep 11 19:57:15 KST 2014 PDA version: T399UVUANI2 CSC version: T399TMBANI2 SW version: T399UVUANI2 Phone IMEI: 354777066443651 Phone SN: RV8FB123M5B Android version: 4.2.2 (JDQ39) Repairing network. Please wait, this can take some time... Phone will restart now. Please don't disconnect cable! Network is successfully repaired. |
01-29-2016, 11:16 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please post here full Software log of "Unlock" operation. What is the status of IMEI Ceti in *#0011# menu? |
01-29-2016, 13:14 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please do the next; 1. Perform "Read Cert" operation. 2. Write Cert file from the Support Area. Try to find and select Network manually after these actions. |
01-29-2016, 13:21 | #7 (permalink) |
Member: 199814 Status: Offline Thanks Meter: 1,960 | Platform: Samsung Android Selected port: COM1 Selected model: SGH-T399N Detected phone model: SGH-T399N Firmware compiled date: Fri Nov 7 11:00:40 KST 2014 PDA version: T399NUVUANK3 CSC version: T399NTMBANK3 SW version: T399NUVUANK3 Phone IMEI: 354777066443651 Phone SN: RV8FB123M5B Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading Certificate... Certificate read successfully write certficate. Platform: Samsung Android Selected port: COM1 Selected model: SGH-T399N Selected file: C:\Users\Asadullah Soomro\Downloads\Cert-SGH-T399N_354796061524513_RV8F90EH0NZ.cert Detected phone model: SGH-T399N Firmware compiled date: Fri Nov 7 11:00:40 KST 2014 PDA version: T399NUVUANK3 CSC version: T399NTMBANK3 SW version: T399NUVUANK3 Phone IMEI: 354777066443651 Phone SN: RV8FB123M5B Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SGH-T399N-29-01-2016_17-20-07-.asec file Writing Certificate... Checking Certificate file... Certificate file successfully checked Writing Certificate ... Certificate has been written successfully Please, restart the phone to apply changes |
01-29-2016, 13:53 | #9 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | - Wipe Factory reset and cache from Recovery - Flash other time this fw or other same version - root phone - repeat procedure of Unlock - try to test with other Sim card and search Network manually. If Fail UNLOCK and network, repeat above steps for Read Cert and Write Other Cert, post here full log and IMPORTANT what say from *#0011# P.D. use Other Cert not this one above and FULL CHARGE BATTERY, not at 12% how above BR allumts |
01-29-2016, 14:23 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please do the next: 1. Reflash the phone. 2. Write "EFS_SGH_T399N_T399NUVUANK3" EFS file from the Support Area. 3. Perform "Repair IMEI" operation. 4. Perform "Repair Network" operation. (optional). Post here result and full Software log of performed operations. |
01-29-2016, 15:42 | #11 (permalink) | ||
Member: 199814 Status: Offline Thanks Meter: 1,960 | Quote:
EFS write done Quote:
01-29-2016, 16:17 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Perform "Repair IMEI" operation, then perform "Unlock" operation, if will be needed. Perform "Repair Network" operation if problem with Network will persist. |
01-29-2016, 16:25 | #13 (permalink) | |
Member: 199814 Status: Offline Thanks Meter: 1,960 | Repair imei Quote:
Platform: Samsung Android Selected port: COM23 Selected model: SGH-T399N Detected phone model: SGH-T399N Firmware compiled date: Fri Nov 7 11:00:40 KST 2014 PDA version: T399NUVUANK3 CSC version: T399NTMBANK3 SW version: T399NUVUANK3 Phone IMEI: 358765060941842 Phone SN: RV8FB123M5B Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SGH-T399N-29-01-2016_20-18-50-.asec file Unlocking phone. This can take some time. Please wait... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. ------------------------ ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SGH-T399N Detected phone model: SGH-T399N Firmware compiled date: Fri Nov 7 11:00:40 KST 2014 PDA version: T399NUVUANK3 CSC version: T399NTMBANK3 SW version: T399NUVUANK3 Phone IMEI: 358765060941842 Phone SN: RV8FB123M5B Android version: 4.4.2 (KOT49H) Repairing network. Please wait, this can take some time... Phone will restart now. Please don't disconnect cable! Network is successfully repaired. and restarted. | |
01-29-2016, 16:52 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | If problem remains the same after all of the performed actions - most likely device has HW problem. Please check phone's HW. |
