01-14-2016, 15:59 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: CIEGO DE AVILA ,CUBA
Member: 1176958 Status: Offline Thanks Meter: 158 | T589W repair imei fail Bienvenido en Octopus Box Samsung software versión 1.7.1 ----------------------------------------------------------------------------------- To connect SGH-T589 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in Octopus Samsung software. ----------------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM31 Modelo seleccionado: SGH-T589 Modo: Normal Modelo del teléfono: SGH-T589 Fecha de creación del firmware: Feb 03 2011 Tiempo de compilación del firmware: 05:00:00 Fecha de salida del firmware: Jun 10 2011 Tiempo de salida del firmware: 20:41:36 Versión del SW: M76XX-TSNCJOLYM-60501005 IMEI antiguo: 357366-04-080085-0 IMEI nuevo: 358211-04-009141-6 Deactivating MSL... MSL deactivate successfully New IMEI successfully written. Para aplicar los cambios, reinicie el teléfono it works thank you octopus box i already flashed the phone here is my logs Bienvenido en Octoplus/Octopus Box Samsung software versión 2.1.6 ----------------------------------------------------------------------------- To connect SGH-T589W phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM229 Modelo seleccionado: SGH-T589W Modo: Normal Modelo del teléfono: SGH-T589W Fecha de creación del firmware: Mar 09 2011 Tiempo de compilación del firmware: 24:00:00 Fecha de salida del firmware: Apr 12 2012 Tiempo de salida del firmware: 20:19:03 IMEI del teléfono: 000000-00-000000-0 Versión del SW: M76XX-TSNCJOLYM-6140 ----------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM229 Modelo seleccionado: SGH-T589W Modo: Normal Modelo del teléfono: SGH-T589W Fecha de creación del firmware: Mar 09 2011 Tiempo de compilación del firmware: 24:00:00 Fecha de salida del firmware: Apr 12 2012 Tiempo de salida del firmware: 20:19:03 Versión del SW: M76XX-TSNCJOLYM-6140 IMEI antiguo: 000000-00-000000-0 IMEI nuevo: 352305-05-091784-5 Deactivating MSL... MSL deactivate successfully IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. but phone has still imei 00000000000000 |
01-16-2016, 12:27 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please upload *.log and *.logx of performed operations to any file-sharing service and post here download link. We will check where can be the problem. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
01-16-2016, 18:45 | #3 (permalink) |
Member: 1176958 Status: Offline Thanks Meter: 158 | thanks my friend but i cant upload anything i live on cuba where the internet is very slow and resctricty i did find the log but cant upload i readed on this forum that u make a especial beta for repair imei this model maybe u can give me a link thanks in advance Log file "C:\Archivos de programa\Octoplus\Octoplus_Samsung\LOG\14-01-2016_08-04-30.log" created (14/01/2016 8:04:33 AM).ERROR : 14/01/2016 8:04:34 AM > Access violation at address 00941520 in module 'OctoplusSamsung.exe'. Read of address 00000004INFO : 14/01/2016 8:04:34 AM > Set up system language Spanish (file: Spanish.ini)INFO : 14/01/2016 8:04:34 AM > Welcome to Octoplus/Octopus Box Samsung software version 1.7.3INFO : 14/01/2016 8:04:34 AM > -----------------------------------------------------------------------------INFO : 14/01/2016 8:04:34 AM > To connect SGH-T589W phone you have to perform the following steps: INFO : 14/01/2016 8:04:34 AM > 1. Disconnect USB cable from phone. INFO : 14/01/2016 8:04:34 AM > 2. Go to Menu->Settings->Applications->Development. INFO : 14/01/2016 8:04:34 AM > 3. Turn on "USB Debugging" option. INFO : 14/01/2016 8:04:34 AM > 4. When message is appear press "Yes". INFO : 14/01/2016 8:04:34 AM > 5. Go to dial window. INFO : 14/01/2016 8:04:34 AM > 6. Enter "*#7284#" number. INFO : 14/01/2016 8:04:34 AM > 7. Set "Diag config" to "USB" value. INFO : 14/01/2016 8:04:34 AM > 8. Restart phone. INFO : 14/01/2016 8:04:34 AM > 9. Press "Read Info" in software.INFO : 14/01/2016 8:05:02 AM > -----------------------------------------------------------------------------INFO : 14/01/2016 8:05:02 AM > To connect SGH-T589 phone you have to perform the following steps: INFO : 14/01/2016 8:05:02 AM > 1. Disconnect USB cable from phone. INFO : 14/01/2016 8:05:02 AM > 2. Go to Menu->Settings->Applications->Development. INFO : 14/01/2016 8:05:02 AM > 3. Turn on "USB Debugging" option. INFO : 14/01/2016 8:05:02 AM > 4. When message is appear press "Yes". INFO : 14/01/2016 8:05:02 AM > 5. Go to dial window. INFO : 14/01/2016 8:05:02 AM > 6. Enter "*#7284#" number. INFO : 14/01/2016 8:05:02 AM > 7. Set "Diag config" to "USB" value. INFO : 14/01/2016 8:05:02 AM > 8. Restart phone. INFO : 14/01/2016 8:05:02 AM > 9. Press "Read Info" in software.INFO : 14/01/2016 8:05:26 AM > -----------------------------------------------------------------------------INFO : 14/01/2016 8:05:26 AM > To connect SGH-T589W phone you have to perform the following steps: INFO : 14/01/2016 8:05:26 AM > 1. Disconnect USB cable from phone. INFO : 14/01/2016 8:05:26 AM > 2. Go to Menu->Settings->Applications->Development. INFO : 14/01/2016 8:05:26 AM > 3. Turn on "USB Debugging" option. INFO : 14/01/2016 8:05:26 AM > 4. When message is appear press "Yes". INFO : 14/01/2016 8:05:26 AM > 5. Go to dial window. INFO : 14/01/2016 8:05:26 AM > 6. Enter "*#7284#" number. INFO : 14/01/2016 8:05:26 AM > 7. Set "Diag config" to "USB" value. INFO : 14/01/2016 8:05:26 AM > 8. Restart phone. INFO : 14/01/2016 8:05:26 AM > 9. Press "Read Info" in software.INFO : 14/01/2016 8:05:55 AM > -----------------------------------------------------------------------------INFO : 14/01/2016 8:05:55 AM > Platform: Samsung AnycallINFO : 14/01/2016 8:05:55 AM > Selected port: COM1INFO : 14/01/2016 8:05:55 AM > Selected model: SGH-T589WINFO : 14/01/2016 8:05:59 AM > Phone was not found on the selected port!INFO : 14/01/2016 8:05:59 AM > Searching for USB diagnostic port...INFO : 14/01/2016 8:05:59 AM > Connecting to phone on COM228INFO : 14/01/2016 8:06:02 AM > Detected phone model: SGH-T589WINFO : 14/01/2016 8:06:02 AM > HW Version: XXXXXXXXXXXXXXINFO : 14/01/2016 8:06:02 AM > Phone IMEI: 000000-00-000000-0WARN : 14/01/2016 8:06:02 AM > Phone connection failedINFO : 14/01/2016 8:06:02 AM > Connecting to phone on COM229INFO : 14/01/2016 8:06:32 AM > Mode: EmergenciaINFO : 14/01/2016 8:06:59 AM > -----------------------------------------------------------------------------INFO : 14/01/2016 8:06:59 AM > Platform: Samsung AnycallINFO : 14/01/2016 8:06:59 AM > Selected port: COM229INFO : 14/01/2016 8:06:59 AM > Selected model: SGH-T589WINFO : 14/01/2016 8:07:02 AM > Phone was not found on the selected port!INFO : 14/01/2016 8:07:02 AM > Searching for USB diagnostic port...INFO : 14/01/2016 8:07:02 AM > Connecting to phone on COM228INFO : 14/01/2016 8:07:05 AM > Detected phone model: SGH-T589WINFO : 14/01/2016 8:07:05 AM > HW Version: XXXXXXXXXXXXXXINFO : 14/01/2016 8:07:06 AM > Phone IMEI: 000000-00-000000-0WARN : 14/01/2016 8:07:06 AM > Phone connection failedINFO : 14/01/2016 8:07:06 AM > Connecting to phone on COM229INFO : 14/01/2016 8:07:35 AM > Mode: EmergenciaINFO : 14/01/2016 8:09:57 AM > -----------------------------------------------------------------------------INFO : 14/01/2016 8:09:57 AM > Platform: Samsung AnycallINFO : 14/01/2016 8:09:57 AM > Selected port: COM229INFO : 14/01/2016 8:09:57 AM > Selected model: SGH-T589WINFO : 14/01/2016 8:09:57 AM > Mode: NormalINFO : 14/01/2016 8:09:57 AM > Phone model: SGH-T589WINFO : 14/01/2016 8:09:57 AM > Firmware compiled date: Mar 09 2011INFO : 14/01/2016 8:09:57 AM > Firmware compiled time: 24:00:00INFO : 14/01/2016 8:09:57 AM > Firmware released date: Apr 12 2012INFO : 14/01/2016 8:09:57 AM > Firmware released time: 20:19:03INFO : 14/01/2016 8:09:57 AM > Phone IMEI: 000000-00-000000-0INFO : 14/01/2016 8:09:57 AM > SW version: M76XX-TSNCJOLYM-6140INFO : 14/01/2016 8:10:10 AM > -----------------------------------------------------------------------------INFO : 14/01/2016 8:10:10 AM > Platform: Samsung AnycallINFO : 14/01/2016 8:10:10 AM > Selected port: COM229INFO : 14/01/2016 8:10:10 AM > Selected model: SGH-T589WINFO : 14/01/2016 8:10:11 AM > Mode: NormalINFO : 14/01/2016 8:10:11 AM > Phone model: SGH-T589WINFO : 14/01/2016 8:10:11 AM > Firmware compiled date: Mar 09 2011INFO : 14/01/2016 8:10:11 AM > Firmware compiled time: 24:00:00INFO : 14/01/2016 8:10:11 AM > Firmware released date: Apr 12 2012INFO : 14/01/2016 8:10:11 AM > Firmware released time: 20:19:03INFO : 14/01/2016 8:10:11 AM > SW version: M76XX-TSNCJOLYM-6140INFO : 14/01/2016 8:10:11 AM > Old IMEI: 000000-00-000000-0INFO : 14/01/2016 8:10:11 AM > New IMEI: 352305-05-091784-5INFO : 14/01/2016 8:10:11 AM > Deactivating MSL...INFO : 14/01/2016 8:10:59 AM > MSL deactivate successfullyINFO : 14/01/2016 8:10:59 AM > IMEI successfully repaired.WARN : 14/01/2016 8:10:59 AM > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!)INFO : 14/01/2016 8:46:18 AM > -----------------------------------------------------------------------------INFO : 14/01/2016 8:46:18 AM > Platform: Samsung AnycallINFO : 14/01/2016 8:46:18 AM > Selected port: COM229INFO : 14/01/2016 8:46:19 AM > Selected model: SGH-T589WINFO : 14/01/2016 8:46:19 AM > Mode: NormalINFO : 14/01/2016 8:46:19 AM > Phone model: SGH-T589WINFO : 14/01/2016 8:46:19 AM > Firmware compiled date: Mar 09 2011INFO : 14/01/2016 8:46:19 AM > Firmware compiled time: 24:00:00INFO : 14/01/2016 8:46:19 AM > Firmware released date: Apr 12 2012INFO : 14/01/2016 8:46:19 AM > Firmware released time: 20:19:03INFO : 14/01/2016 8:46:19 AM > SW version: M76XX-TSNCJOLYM-6140INFO : 14/01/2016 8:46:19 AM > Old IMEI: 000000-00-000000-0INFO : 14/01/2016 8:46:19 AM > New IMEI: 352305-05-091784-5INFO : 14/01/2016 8:46:19 AM > Deactivating MSL...INFO : 14/01/2016 8:46:59 AM > MSL deactivate successfullyINFO : 14/01/2016 8:46:59 AM > IMEI successfully repaired.WARN : 14/01/2016 8:46:59 AM > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Log file "C:\Archivos de programa\Octoplus\Octoplus_Samsung\LOG\14-01-2016_08-04-30.log" closed (14/01/2016 9:03:36 AM). |
01-18-2016, 10:25 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please reflash the phone with "T589WUQLD4_YVLLD4" firmware from the Support Area, then repeat "Repair IMEI" operation. Post here result and full Software log performed operations. |
01-24-2016, 17:07 | #7 (permalink) |
Member: 1176958 Status: Offline Thanks Meter: 158 | here is a log that i flashed ok but now imei is null and worst that restar every a while and the worst thing is octopus dosent see "*#7284#" number dosent work anymore i can see a ports on admistrator it show on fact other tool see but octopus dosent even when i choose port manualy please hel me |
01-24-2016, 17:14 | #8 (permalink) |
Member: 1176958 Status: Offline Thanks Meter: 158 | sorry i forget the log Bienvenido en Octoplus/Octopus Box Samsung software versión 2.1.6 ----------------------------------------------------------------------------- To connect SM-G7105 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+MODEM+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "DM/DUM over HSIC" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------- To connect SGH-T589R phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM1 Modelo seleccionado: SGH-T589R ¡En el puerto seleccionado el teléfono no fue detectado! Intentando a buscar el puerto USB diagnóstico... Intentando a conectar el teléfono en COM228 La conexión con el teléfono falló Intentando a conectar el teléfono en COM229 Modo: Emergencia ----------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM229 Modelo seleccionado: SGH-T589R ¡En el puerto seleccionado el teléfono no fue detectado! Intentando a buscar el puerto USB diagnóstico... Intentando a conectar el teléfono en COM228 La conexión con el teléfono falló Intentando a conectar el teléfono en COM229 La conexión con el teléfono falló ¡Puertos diagnósticos no encontrados! Intentando a conectar el teléfono en COM228 La conexión con el teléfono falló Intentando a conectar el teléfono en COM4 La conexión con el teléfono falló ----------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM228 Modelo seleccionado: SGH-T589R ¡En el puerto seleccionado el teléfono no fue detectado! ----------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM229 Modelo seleccionado: SGH-T589R ¡En el puerto seleccionado el teléfono no fue detectado! ----------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM229 Modelo seleccionado: SGH-T589R ¡En el puerto seleccionado el teléfono no fue detectado! Seleccione el archivo de firmware: T589WUQLD4_YVLLD4.oct Please put the phone into Download Mode and connect USB cable. To put SGH-T589R into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume + " + "Volume -" keys. 3. Insert usb cable. Searching for a phone. Please wait... Found phone on El archivo fue creado para otro modelo de teléfono ----------------------------------------------------------------------------- To connect SGH-T589W phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. Please put the phone into Download Mode and connect USB cable. To put SGH-T589W into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume + " + "Volume -" keys. 3. Insert usb cable. Searching for a phone. Please wait... Please put the phone into Download Mode and connect USB cable. To put SGH-T589W into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume + " + "Volume -" keys. 3. Insert usb cable. Searching for a phone. Please wait... Found phone on Firmware write started. Escribiendo la sección mibib... L a sección mibib ha sido escrita con éxito Escribiendo la sección qcsbl... L a sección qcsbl ha sido escrita con éxito Escribiendo la sección oemsbl... L a sección oemsbl ha sido escrita con éxito Escribiendo la sección amss... L a sección amss ha sido escrita con éxito Escribiendo la sección arm11boot... L a sección arm11boot ha sido escrita con éxito Escribiendo la sección boot.img... L a sección boot.img ha sido escrita con éxito Escribiendo la sección recovery.img... L a sección recovery.img ha sido escrita con éxito Escribiendo la sección system.rfs... L a sección system.rfs ha sido escrita con éxito Escribiendo la sección data.rfs... L a sección data.rfs ha sido escrita con éxito Escribiendo la sección csc.rfs... L a sección csc.rfs ha sido escrita con éxito Para aplicar los cambios, reinicie el teléfono La escritura del firmware ha sido completada con éxito here is now afther flashed Bienvenido en Octoplus/Octopus Box Samsung software versión 2.1.6 ----------------------------------------------------------------------------- To connect SM-G7105 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+MODEM+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "DM/DUM over HSIC" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------- To connect SGH-T589R phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM1 Modelo seleccionado: SGH-T589R ¡En el puerto seleccionado el teléfono no fue detectado! Intentando a buscar el puerto USB diagnóstico... Intentando a conectar el teléfono en COM228 La conexión con el teléfono falló Intentando a conectar el teléfono en COM229 Modo: Emergencia ----------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM229 Modelo seleccionado: SGH-T589R ¡En el puerto seleccionado el teléfono no fue detectado! Intentando a buscar el puerto USB diagnóstico... Intentando a conectar el teléfono en COM228 La conexión con el teléfono falló Intentando a conectar el teléfono en COM229 La conexión con el teléfono falló ¡Puertos diagnósticos no encontrados! Intentando a conectar el teléfono en COM228 La conexión con el teléfono falló Intentando a conectar el teléfono en COM4 La conexión con el teléfono falló ----------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM228 Modelo seleccionado: SGH-T589R ¡En el puerto seleccionado el teléfono no fue detectado! ----------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM229 Modelo seleccionado: SGH-T589R ¡En el puerto seleccionado el teléfono no fue detectado! ----------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM229 Modelo seleccionado: SGH-T589R ¡En el puerto seleccionado el teléfono no fue detectado! Seleccione el archivo de firmware: T589WUQLD4_YVLLD4.oct Please put the phone into Download Mode and connect USB cable. To put SGH-T589R into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume + " + "Volume -" keys. 3. Insert usb cable. Searching for a phone. Please wait... Found phone on El archivo fue creado para otro modelo de teléfono ----------------------------------------------------------------------------- To connect SGH-T589W phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. Please put the phone into Download Mode and connect USB cable. To put SGH-T589W into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume + " + "Volume -" keys. 3. Insert usb cable. Searching for a phone. Please wait... Please put the phone into Download Mode and connect USB cable. To put SGH-T589W into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume + " + "Volume -" keys. 3. Insert usb cable. Searching for a phone. Please wait... Found phone on Firmware write started. Escribiendo la sección mibib... L a sección mibib ha sido escrita con éxito Escribiendo la sección qcsbl... L a sección qcsbl ha sido escrita con éxito Escribiendo la sección oemsbl... L a sección oemsbl ha sido escrita con éxito Escribiendo la sección amss... L a sección amss ha sido escrita con éxito Escribiendo la sección arm11boot... L a sección arm11boot ha sido escrita con éxito Escribiendo la sección boot.img... L a sección boot.img ha sido escrita con éxito Escribiendo la sección recovery.img... L a sección recovery.img ha sido escrita con éxito Escribiendo la sección system.rfs... L a sección system.rfs ha sido escrita con éxito Escribiendo la sección data.rfs... L a sección data.rfs ha sido escrita con éxito Escribiendo la sección csc.rfs... L a sección csc.rfs ha sido escrita con éxito Para aplicar los cambios, reinicie el teléfono La escritura del firmware ha sido completada con éxito ----------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM229 Modelo seleccionado: SGH-T589W ¡En el puerto seleccionado el teléfono no fue detectado! Intentando a buscar el puerto USB diagnóstico... Intentando a conectar el teléfono en COM228 La conexión con el teléfono falló Intentando a conectar el teléfono en COM229 Modo: Emergencia ----------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM229 Modelo seleccionado: SGH-T589W ¡En el puerto seleccionado el teléfono no fue detectado! Intentando a buscar el puerto USB diagnóstico... Intentando a conectar el teléfono en COM228 La conexión con el teléfono falló Intentando a conectar el teléfono en COM229 Modo: Emergencia ----------------------------------------------------------------------------- Plataforma: Samsung Anycall Puerto seleccionado: COM228 Modelo seleccionado: SGH-T589W ¡En el puerto seleccionado el teléfono no fue detectado! Intentando a buscar el puerto USB diagnóstico... Intentando a conectar el teléfono en COM228 La conexión con el teléfono falló Intentando a conectar el teléfono en COM229 Modo: Emergencia |
01-25-2016, 16:11 | #10 (permalink) |
Member: 1176958 Status: Offline Thanks Meter: 158 | *#0808# code dosent open neither please anothe tips-- *#9090# dosent work too the interesting thing is that before it does work on port conection it does show a samsung compor but soft it dosent take it even if u take manualy please help me now phone is worst because restar every 10 minutes thanks octopus team the best ever |
01-25-2016, 16:55 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please make Factory Reset, then reflash the phone again. Check whether phone accepts *#7284#, or *#0808#, or ##3424# codes. |
01-26-2016, 16:28 | #12 (permalink) |
Member: 1176958 Status: Offline Thanks Meter: 158 | thanks sir I did everything but not luck dint work y try another pc is the same no conection no conection with soft Last edited by Octopus box; 01-26-2016 at 17:15. |
01-27-2016, 15:09 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | You need to set "Diag config" to "USB" value in *#7284#, or *#0808#, or ##3424# menu for connection of the phone. |
