06-05-2016, 03:11 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Jeddah, Saudi Arabia
Member: 1911337 Status: Offline Thanks Meter: 38 | tab a6 t285 frp lock Strange problem guys when solving frp lock problem for t285 it doesn't open setting may be some new security. So any one faced this issue? and if there is any solution? Any help will be appreciated BR Abdulah Shafique |
06-06-2016, 10:37 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. You can try to reflash the tab with older (by release date) firmware, then repeat "Reset FRP/Reactivation/EE" operation. |
06-07-2016, 06:03 | #3 (permalink) |
Member: 1911337 Status: Offline Thanks Meter: 38 | tried another firmware, still stuck at the end point. need urgent help plz. http://s33.postimg.org/epzvx2f73/wwwe.png BR Abdullah Shafique |
06-07-2016, 10:59 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You should try to write different, older (by release date) firmwares. Currently we can't say which firmware exactly will allow to safely downgrade and remove FRP lock for SM-T285. |
01-02-2017, 16:50 | #9 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: islamabad
Member: 352880 Status: Offline Sonork: 100.1609545 Thanks Meter: 554 | Quote:
Welcome to Octoplus/Octopus Box Samsung software version 2.4.5 ----------------------------------------------------------------------------------- To connect SM-N910W8 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. -------------------------------------------------------------------------------------- Selected interface: USB Searching for device. Please wait... Waiting for device... Device was not found! Operation was cancelled! Performed by 2.4.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM85 Selected model: SM-T285 Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-T285 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Backup and reset" and make "Factory data reset" Performed by 2.4.5 Software version. | |
The Following 2 Users Say Thank You to master mobiles For This Useful Post: |
