Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
View Poll Results: Is Thread useful
Yes 2,995 92.78%
No 233 7.22%
Voters: 3228. You may not vote on this poll
Old 10-18-2014, 09:10   #46 (permalink)
Member: 289990
Thanks Meter: 134
Repair NVM fixed in thise update ?
Old 10-18-2014, 10:39   #47 (permalink)
Member: 612439
Thanks Meter: 34
Welcome to Octoplus/Octopus Box Samsung software version 1.7.0
To connect SM-N9005 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Go to dial window.
11. Enter "*#9090#" number.
12. Set "Diag config" to "USB" value.
13. Restart phone.
14. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM240
Selected model: SM-N9005
Please, press "OK" button on the phone to allow USB debugging..
Detected phone model: SM-N9005
Firmware compiled date: Mon Jul 28 21:56:29 KST 2014
PDA version: N9005XXUGNG1
CSC version: N9005OJVGNH1
SW version: N9005XXUGNG1
Phone IMEI: 359092054765288
Phone SN: RV1D956TFKR
Android version: 4.4.2 (KOT49H)
Reading security backup, please wait...
Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung
\BACKUP\Security-SM-N9005-359092054765288-18-10-2014_11-53-
37-.asec file
Wiping EFS...
EFS wipe successfully
Phone will restart now
Operation was canceled
Writing Certificate failed
Port is busy
Phone was not found on the selected port!
Searching for USB diagnostic port...
No diagnostic ports found!
Connecting to phone on COM3
Phone connection failed
Selected action can’t be performed
Selected port: COM3
Mode: Emergency
Write IMEI failed
Selected port: COM3
Selected port: COM3
Selected file: D:\BOX\octapus sam\Cert-SM-N900-358021058471446-
RF1D93A24AK.cert
Checking Certificate file...
Checking Certificate failed
Selected port: COM239
RF1D93A24AK.cert
RF1D93A24AK.cert
Old 10-18-2014, 10:58   #48 (permalink)
Member: 612439
Thanks Meter: 34
i changed the cert file and solved my problem nut i have network just for 2 second
Old 10-18-2014, 11:24   #49 (permalink)
sameenshah123's Avatar
Member: 619308
Sonork: 100.1591829
Thanks Meter: 243
i need cert for sm-c115 and smp5220. plz i need it urgent thanks
Old 10-18-2014, 15:58   #50 (permalink)
Member: 2276446
Hi Guys i can not found the certificate file for the SM-N9005, someone can help me please?!?
TANKS!
Old 10-18-2014, 16:02   #51 (permalink)
Member: 612439
Thanks Meter: 34
u can use with n900 cert file
Old 10-18-2014, 16:14   #52 (permalink)
Member: 2257067
imei change for g900F? itīs possible?
Old 10-18-2014, 17:06   #53 (permalink)
Member: 2276446
Farzin i have try but the certificate is not compatible with n9005
Old 10-18-2014, 18:18   #54 (permalink)
orx
Moderator
orx's Avatar
Member: 1825965
Thanks Meter: 693
today my birthday 99 years.. no one can give me a help ? certi file n9005 european
thanks
Old 10-18-2014, 18:50   #55 (permalink)
Member: 2175541
Thanks Meter: 16
Hello...
Can someone post The Cert file for N9005 LTE 32Gb?
Thank you
Old 10-19-2014, 10:07   #56 (permalink)
Member: 612439
Thanks Meter: 34
i tested this cert on n9005 but i had network just fo 2 second
The Following 4 Users Say Thank You to FARZIN-GSM For This Useful Post:
Old 10-19-2014, 10:28   #57 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 10,650
Try to write Qcn of other same model with Fully Working Network, in CERT file there isn't Network, this is in Qcn file.
allumts
Old 10-19-2014, 10:33   #58 (permalink)
allumts's Avatar
Member: 1564612
This CERT N900 is one of the first shared in this forum, if all you continue using always this is obvius that can be any issues, ceck this: *#0011# if is CERT Pass, try to write good Qcn how wrote above.
allumts
Old 10-19-2014, 10:45   #59 (permalink)
allumts's Avatar
Member: 1564612
@elzumba01 and ALL, leave this Thread Clear, Only for Share CERT file, no post here question or other thinghs.
Also, for MORE INFO about HOW TO use Cert file, Qcn, itc...there's one Sticky thread for all question Here:
Important note!! About "read/write cert" and "wipe efs"
and if in post #10 "Click for open" spoiler can find Step by step the procedure with New method.
Note: Now in Sw V. 1.7.1 is Supported "Qcn Read/Write" so cannot use more QPST free program. Very soon will be updatate for many other models if not find this option for you model.
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 10-19-2014, 10:57   #60 (permalink)
allumts's Avatar
Member: 1564612
13. Restart phone.
37-.asec file
Wiping EFS...
Selected port: COM3
RF1D93A24AK.cert
RF1D93A24AK.cert
RF1D93A24AK.cert
EDIT of my post #57/58
@FARZIN-GSM,
But what have Write you?, is Wrong "WRITE CERT" file, not see that is always FAILED?, if not Write CERT file and Sw get out CERT Compatibility and CERT write OK, what want from you phone?, have also restored Qcn Bkp after all procedure?, please Read carefullu Step by Step HOW TO Use this new Procedure.
Update you Octopus SW to 1.7.1 in V. 1.7.0 there isn't QCN Read/Write Option.
_______
allumts
Page generated in 0.22916 seconds with 9 queries
