01-20-2015, 15:36 | #1 (permalink) |
No Life Poster Join Date: Apr 2012 Location: Black Market Age: 39
Member: 1744748 Status: Offline Thanks Meter: 752 | UART port for G850xx Phone repair I would like to inform you that you have great solutions and amazing support for your users. I have not seen such a committed team who responds to their customers issues. Anyways, I had a request / proposal / feedback as we have models from At&t which are not rootable. I was hoping if your team can provide uart compatible cert writing which would not require root. As we can easily reset efs via code. This would really help the community. Thanks, |
01-20-2015, 15:52 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hi. Thanks for your pleasant words and qualified helps and advices to out users in our section, always pleasantly to see posts from experienced spesialist. About your suggestions - we will think how to do this and will try to release these features in one of the future Software updates. Thanks. |
01-26-2015, 19:53 | #3 (permalink) |
Member: 1744748 Status: Offline Thanks Meter: 752 | Just to confirm the N910A / G850 variant are working via Octopus using the UART potrt... I still have to try N915T using the N910T model... unless OCtopus can send me the BETA test software Thanks, |
01-26-2015, 23:48 | #5 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: ATT IPHONE -SL3 LBF,MAC EFI
Member: 542009 Status: Offline Thanks Meter: 54 | Quote:
Certificate is not compatible Writing CERT failed Or do you have any clue can write CERT g850a over UART cable? Thanks Note: im using G850F CERT write to G850A Last edited by 7777; 01-26-2015 at 23:49. Reason: Add note | |
01-27-2015, 01:12 | #6 (permalink) | |
Freak Poster Join Date: Nov 2013 Location: remotely
Member: 2063388 Status: Offline Thanks Meter: 80 | Quote:
Is there root for the g850a ? If so try selecting g900t Otherwise you can always write a cert via at commands | |
01-30-2015, 01:52 | #8 (permalink) | |
Thanks for your help I did wipe EFS by code i did try g900f to g870a but checked CERT fail I will try again use n900t write to g870a as you mentioned | |
01-30-2015, 02:47 | #9 (permalink) | |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Quote:
01-30-2015, 22:52 | #11 (permalink) |
No Life Poster Join Date: Dec 2003
Member: 47384 Status: Offline Thanks Meter: 8 | To connect SM-G850A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-G850A Selected file: F:\Samsung\SS CERT FILE\g850f\Cert-SM-G850F- 355210062179805-RF8F91MC20Z.cert Powered on perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM10 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is not compatible Writing Certificate failed The manual is selected Last edited by baomobile; 01-30-2015 at 22:53. Reason: add note |
01-31-2015, 02:54 | #12 (permalink) |
Member: 1744748 Status: Offline Thanks Meter: 752 | Clearly G850F is not compatible with G850 A / W ... if you use the correct cert file it would work flawlessly.... have done more than 10 devices |
The Following User Says Thank You to ysr84 For This Useful Post: |
01-31-2015, 05:00 | #13 (permalink) | |
Let me know Thanks | |
