12-19-2014, 10:15 | #1 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2101398 Status: Offline Thanks Meter: 8 | Unable to connect to UART Galaxy Alpha G850A [Solved] Welcome to Octoplus/Octopus Box Samsung software version 1.7.8 ----------------------------------------------------------------------------------- To connect SM-G850A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G850A Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G850A Firmware compiled date: Thu Aug 28 18:01:29 KST 2014 PDA version: G850AUCU1ANH8 CSC version: G850AATT1ANH8 SW version: G850AUCU1ANH8 Phone IMEI: 355xxxxxxx Phone SN: R38F90AJHGF Android version: 4.4.4 (KTU84P) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G850A Connect phone to UART cable, phone must be ON and screen must be permanently active! Searching for a phone. Please wait... Phone was not found! Factory Unlock operation failed! ----------------------------------------------------------------------------------- OTHER PHONES CONNECT UART Platform: Samsung Android Selected port: COM7 Selected model: SM-G850A Connect phone to UART cable, phone must be ON and screen must be permanently active! Searching for a phone. Please wait... Found phone on COM7 Reading info... Phone model: SM-G900A Phone IMEI: 352xxx MSL address: 0026041986 Warning: Selected model (SM-G850A) differs from the detected one (SM-G900A)! Factory Unlock operation failed! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-G850A Connect phone to UART cable, phone must be ON and screen must be permanently active! Searching for a phone. Please wait... Found phone on COM7 Reading info... Phone model: SGH-I337 Phone IMEI: 354xxxx MSL address: R31D80C0LA Warning: Selected model (SM-G850A) differs from the detected one (SGH-I337)! Factory Unlock operation failed! ----------------------------------------------------------------------------------- Last edited by Octopus box; 12-19-2014 at 10:40. |
12-19-2014, 10:23 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. To connect SM-G850A phone You need to block highlighted pin with a tape and use Samsung Micro UART C3300k/C3303k cable with 523-525kOhm resistor for connection. |
12-19-2014, 10:39 | #3 (permalink) |
Member: 2101398 Status: Offline Thanks Meter: 8 | WORKED LIKE A CHARM...THANKS Connect phone to UART cable, phone must be ON and screen must be permanently active! Searching for a phone. Please wait... Found phone on COM7 Reading info... Phone model: SM-G850A Phone IMEI: 355XXX MSL address: R38F90AJHG Requesting MSL code... Connecting to server Username: XXXXX Connect successfully to server. Checking smart card... Smart card successfully checked. Sending device information... Checking balance... Your balance: 21 credits. Checking request.. Sending request... Order ID: 73698 MSL code has been obtained successfully! Deactivating MSL... MSL deactivate successfully Unlocking phone... Factory Unlock operation successfully completed! To unlock please type '00000000' (8 zeros). Please, restart the phone to apply changes |
