12-20-2016, 11:06 | #3 (permalink) | |
No Life Poster Join Date: May 2005 Location: Romania Focsani
Member: 149135 Status: Offline Thanks Meter: 234 | Quote:
Welcome to Octoplus/Octopus Box Samsung software version 2.4.6 ----------------------------------------------------------------------------------- To connect SM-A500FU phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM81 Selected model: SM-A500FU Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed Performed by 2.4.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM81 Selected model: SM-A500FU Detected phone model: SM-A500FU Firmware compiled date: Thu Aug 4 18:43:25 KST 2016 PDA version: A500FUXXS1CPH2 CSC version: A500FUVFG1CPG1 SW version: A500FUXXU1CPG2 Phone SN: RF8GC0662YA Android version: 6.0.1 (MMB29M) Sales code: CNX Country: Romania HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Security patch level: 2016-08-01 Codename: a5ultexx Checking Root: Phone is Rooted. Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.4.6 Software version. | |
12-20-2016, 11:38 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | As You can see from Software log, your phone has one of the latest firmwares: Quote:
Note: downgrading of phone firmware can damage your device. You can try to do this only on your own risk. | |
01-23-2017, 14:24 | #5 (permalink) |
No Life Poster Join Date: Jul 2001 Location: handline Age: 48
Member: 5397 Status: Offline Thanks Meter: 38 | Same problem Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 ----------------------------------------------------------------------------------- To connect SM-J700H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-A500FU phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. Platform: Samsung Android Selected port: COM1050 Selected model: SM-A500FU Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1050 Selected model: SM-A500FU Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1050 Selected model: SM-A500FU Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-A500FU Firmware compiled date: Thu Aug 4 18:43:25 KST 2016 PDA version: A500FUXXS1CPH2 CSC version: A500FUVBB1CPG1 SW version: A500FUXXU1CPG2 Phone SN: RF8GC1BZR1P Android version: 6.0.1 (MMB29M) Sales code: VDH Country: Hungary HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Security patch level: 2016-08-01 Codename: a5ultexx Checking Root: Phone is Rooted. Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.4.7 Software version. |
01-23-2017, 14:56 | #6 (permalink) |
No Life Poster Join Date: Feb 2002 Location: UK
Member: 9732 Status: Offline Thanks Meter: 27 | Hi Try with this flash file Model SM-A500FU Model name GALAXY A5 Security Patch Level 2016-07-01 Product code DHR PDA A500FUXXU1CPG2 CSC A500FUDHX1CPG1 Last edited by KATOUE; 01-23-2017 at 15:03. |
