08-12-2013, 19:00 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | unlock M440S WITHOUT SUCCESS Platform: Samsung Android Selected port: COM8 Selected model: SHW-M440S Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Mar 27 16:36:42 KST 2013 Android version: 4.1.2 (JZO54K) Unlocking phone... Phone is successfully unlocked AFTER STILL ASK CODE PLZ HOW CAN I SOLVED THIS? |
08-24-2013, 20:01 | #3 (permalink) | |
Freak Poster Join Date: Mar 2010 Location: indonesia
Member: 1272849 Status: Offline Thanks Meter: 8 | Quote:
INFO : 8/24/2013 11:35:18 PM > Set up system language English (file: English.ini) INFO : 8/24/2013 11:35:18 PM > Welcome to Octoplus/Octopus Box Samsung software version 1.2.9 INFO : 8/24/2013 11:35:18 PM > ----------------------------------------------------------------------------------- INFO : 8/24/2013 11:35:18 PM > To connect SHW-M440S phone you have to perform the following steps: INFO : 8/24/2013 11:35:18 PM > 1. Disconnect USB cable from phone. INFO : 8/24/2013 11:35:18 PM > 2. Go to Menu->Settings->Developer options. INFO : 8/24/2013 11:35:18 PM > 3. Turn on "USB Debugging" option. INFO : 8/24/2013 11:35:18 PM > 4. When message is appear press "Yes". INFO : 8/24/2013 11:35:18 PM > 5. Connect usb cable to phone. INFO : 8/24/2013 11:35:18 PM > 6. Go to dial window. INFO : 8/24/2013 11:35:18 PM > 7. Enter *#9090# number. INFO : 8/24/2013 11:35:18 PM > 8. Set speed to 115200. INFO : 8/24/2013 11:35:18 PM > 9. Reboot phone. INFO : 8/24/2013 11:35:18 PM > 10. Press "Read Info" in software. WARN : 8/24/2013 11:35:24 PM > Please switch your phone to the download mode and connect it to a PC. WARN : 8/24/2013 11:35:24 PM > To put SHW-M440S phone into download mode you have to perform the following steps: WARN : 8/24/2013 11:35:24 PM > 1. Reconnect phone battery. WARN : 8/24/2013 11:35:24 PM > 2. Press and hold "Volume - " + "Home" + "Power" buttons. WARN : 8/24/2013 11:35:24 PM > 3. When phone turns on press "Volume+" button. INFO : 8/24/2013 11:35:46 PM > Found phone on INFO : 8/24/2013 11:35:46 PM > Reading PIT... ERROR : 8/24/2013 11:35:46 PM > Reading PIT failed. INFO : 8/24/2013 11:51:55 PM > ----------------------------------------------------------------------------------- INFO : 8/24/2013 11:51:55 PM > Platform: Samsung Android INFO : 8/24/2013 11:51:55 PM > Selected port: COM122 INFO : 8/24/2013 11:51:55 PM > Selected model: SHW-M440S ERROR : 8/24/2013 11:51:55 PM > Proper android device not found. Make shure that "USB debug" option on the device is turned on. INFO : 8/24/2013 11:51:55 PM > Checking Root: INFO : 8/24/2013 11:51:55 PM > Phone is not Rooted. Rooting phone... ERROR : 8/24/2013 11:51:57 PM > Rooting phone failed. INFO : 8/24/2013 11:52:16 PM > Selected firmware file: Roor_SHW_M440S.oct WARN : 8/24/2013 11:52:49 PM > Please switch your phone to the download mode and connect it to a PC. WARN : 8/24/2013 11:52:49 PM > To put SHW-M440S phone into download mode you have to perform the following steps: WARN : 8/24/2013 11:52:49 PM > 1. Reconnect phone battery. WARN : 8/24/2013 11:52:49 PM > 2. Press and hold "Volume - " + "Home" + "Power" buttons. WARN : 8/24/2013 11:52:49 PM > 3. When phone turns on press "Volume+" button. INFO : 8/24/2013 11:52:49 PM > Found phone on INFO : 8/24/2013 11:52:49 PM > Firmware write started. WARN : 8/24/2013 11:52:49 PM > Please select firmware with PIT ERROR : 8/24/2013 11:52:49 PM > Writing Firmware Failed | |
08-26-2013, 08:07 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please connect your phone directly to USB motherboard USB port; don't use any USB hubs or PCI USB cards - use motherboard USB port only! Also try on another PC. |
11-24-2013, 15:56 | #5 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Gujranwala Pakistan Age: 48
Member: 71190 Status: Offline Sonork: 100.1580485 Thanks Meter: 87 | there is no frimware on octopus support with pit file Quote:
for m440s there is no frimware on octopus support with pit file also not found pit file any where | |
12-03-2013, 18:11 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have uploaded firmware with PIT file for You. Please download it. https://mega.co.nz/#!ycVAUJhZ!e5rE4m...hoi9YBnxFthUIg |
12-09-2013, 14:26 | #9 (permalink) | |
Member: 71190 Status: Offline Sonork: 100.1580485 Thanks Meter: 87 | Quote:
