Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 05-15-2017, 09:25   #1 (permalink)
domestik's Avatar
Member: 40118
Thanks Meter: 87
Unlock via MSL code AKSEED error [Answered]
Trying to unlock A910f via calculated MSL (uo5oq.com):
Octoplus/Octopus Samsung Factory Services v.2.5.4
Connecting to server..OK
Username:
Authorization..
Login error: Wrong username!
Selected interface: USB
Searching for device. Please wait...
Waiting for device...
Found device on COM159
Reading info...
Detected device model: SM-A910F
HW Version: SM-A910FZKDCOO
PDA version: A910FUBU1AQC2
CSC version: A910FUUB1AQC1
CP version: A910FXXU1AQC6
Device SN: R28HB42MDSV
Device IMEI: 351718-08-286391-3
FRP/Reactivation: UNLOCK
MSL code: 0F574A1157451A25110D523C2B105C29
Deactivating MSL...
AKSEED error!
Old 05-15-2017, 09:48   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 24,414
Hello.
Please upload *.log and *.logx files of performed operations to any file-sharing service and post here download link. We will check what causes the problem.
*.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder.
Old 05-15-2017, 09:54   #3 (permalink)
domestik's Avatar
Member: 40118
Thanks Meter: 87
https://yadi.sk/d/9JWdDoF-3J9oxv
Old 05-15-2017, 11:29   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
Please perform the operation via UART interface and post here the result.
Old 05-15-2017, 12:11   #5 (permalink)
domestik's Avatar
Member: 40118
Thanks Meter: 87
I have no working uart cable unfortunately... Any usb solution?
Old 05-15-2017, 13:02   #6 (permalink)
Member: 1146942
Sonork: 100.1587278
If operation ends up with an error using USB interface - You should try to process the phone via UART cable.
Old 05-15-2017, 17:31   #7 (permalink)
hoang's Avatar
Member: 10485
Sonork: 100.66876
Thanks Meter: 395
SM-A910F is qualcomm based phone, so Factory unlock need UART interface, or root it, then unlock via adb...
Old 05-18-2017, 10:13   #8 (permalink)
skyulock's Avatar
Member: 757064
Thanks Meter: 245
a910f is UART INTERFACE TO UNLOCKED
Old 10-18-2017, 15:24   #9 (permalink)
Member: 595977
INFO : 10/18/2017 7:51:45 AM > Reading info...
INFO : 10/18/2017 7:51:57 AM > Detected device model: SM-A520F
INFO : 10/18/2017 7:51:57 AM > HW Version: PHE
INFO : 10/18/2017 7:51:57 AM > PDA version: A520FXXU2BQIE
INFO : 10/18/2017 7:51:57 AM > CSC version: A520FPHE2BQI1
INFO : 10/18/2017 7:51:57 AM > CP version: A520FXXU2BQIE
INFO : 10/18/2017 7:51:57 AM > Device SN: R58J55CEKPL
INFO : 10/18/2017 7:51:57 AM > Device IMEI: 358651-08-5030XXX
INFO : 10/18/2017 7:51:57 AM > FRP/Reactivation: UNLOCK
WARN : 10/18/2017 7:51:57 AM > MSL code: 325A000F08312A5452582D0A034B324E
INFO : 10/18/2017 7:51:57 AM > Deactivating MSL...
ERROR : 10/18/2017 7:52:03 AM > AKSEED error!
Old 10-18-2017, 15:31   #10 (permalink)
Member: 1146942
Sonork: 100.1587278
Deactivating MSL...
AKSEED error!
Unlocking via MSL code is currently not supported via USB cable for this phone model, need to use special UART Type-C cable. Also You can unlock this phone via Octoplus Factory Unlock Service.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 10-18-2017, 23:42   #11 (permalink)
Member: 595977
Who sells or has the pinout of that cable
Old 10-20-2017, 20:30   #12 (permalink)
Member: 1741973
Thanks Meter: 114
unlocking via MSL those type C USB pin android 7.0 cant unlock by any box using usb cable alone.. the question is where is the special type C uart cable? why not give a warning that those phone cant unlock by USB cable(cmd not supported) before they release MSL unlock. too late to explain. such a waste buying MSL code. that damn MSL code cant be refunded!
MSL unlock good for 6.0.1, can unlock by usb cable
MSL unlock bad for 7.0 up, special uart cable required
The Following 2 Users Say Thank You to chmsc_ELX For This Useful Post:
Page generated in 0.31564 seconds with 7 queries
