08-13-2015, 20:31 | #1 (permalink) |
Freak Poster Join Date: May 2012
Member: 1756668 Status: Offline Thanks Meter: 4 | Unlocking / IMEI REPAIR SM-G900T I am trying to unlock an S5 (G900T) and this is the error I get: Welcome to Octoplus/Octopus Box Samsung software version 2.0.3 ----------------------------------------------------------------------------------- To connect SM-G900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM101 Selected model: SM-G900T Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM101 Selected model: SM-G900T Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM101 Selected model: SM-G900T Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM101 Selected model: SM-G900T Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- To connect SM-G900A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM101 Selected model: SM-G900A Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. I also tried it for another device G900A and same issue as you can see in the logs. I tried rebooting the computer and I also tried to reinstall samsung drivers and I wiped both phones and wiped the cache but nothing seems to work. |
08-14-2015, 07:29 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Phone's on Android 5.x have their Diagnostic port disabled. Try to enable CP logging in Recovery Mode, then check whether phone is being detected by PC. |
08-14-2015, 17:40 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please make Factory Reset, then reflash the phone. Check, whether Enable CP logging option becomes available after reflashing. |
08-15-2015, 10:14 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Reflash the phone with Android 5.0 firmware, then heck, whether Enable CP logging option becomes available in Recovery Mode. |
