Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 08-15-2013, 13:30   #1 (permalink)
alfin5557's Avatar
Member: 176999
Thanks Meter: 32
Thumbs up Unlocking SHV-E160s problem [Solved]
help for unlocking phone SHV-E160s unlocking problem, use octopus samsung tool can't unlocking this phone, I have try flashing with firmware in support area
this log for progress :
Welcome to Octoplus/Octopus Box Samsung software version 1.2.4
To connect SHV-E160S phone you have to perform the following
steps:
1. Go to dial window.
2. Enter "319712358" number.
3. Enter "996412" password.
4. Go to System->SIO mode.
5. Select "Modem" radio button for USB section.
6. Go to dial window.
7. Enter "*#9090#" number.
8. Set "Diag config" to "USB" value.
9. Restart phone.
10. Press "Read Info" in software.
Selected firmware file: E160S.UH24.1912_CL966809_REV02
_ROOTED.oct <<<<< this file from supprot area
Please switch your phone to the download mode and connect it to a
PC.
To put SHV-E160S phone into download mode you have to perform the
following steps:
1. Reconnect phone battery.
2. Press and hold "Volume - " + "Home" + "Power" buttons.
3. When phone turns on press "Volume+" button.
Found phone on
Firmware write started.
Writing BOOT section...
BOOT section has been written successfully.
Writing RECOVERY section...
RECOVERY section has been written successfully.
Writing MODEM section...
MODEM section has been written successfully.
Writing MDM section...
MDM section has been written successfully.
Writing SYSTEM section...
SYSTEM section has been written successfully.
Firmware writing successfully completed.
Platform: Samsung Anycall
Selected port: COM34
Selected model: SHV-E160S
Mode: Normal
Phone model: SHV-E160S
Firmware compiled date: May 03 2012
Firmware compiled time: 10:00:00
Firmware released date: Jul 31 2012
Firmware released time: 13:16:06
Phone IMEI: 359795-04-237570-1
SW Version: M9200B-SCAQCSZD-3.4.706025
Unlocking phone...
Phone unlocking failed
help for solution my problem,thx for respons
Old 08-15-2013, 13:48   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,413
Please make repair NVM, then re-flash and check whether your phone is unlocked.
Old 08-15-2013, 14:58   #3 (permalink)
alfin5557's Avatar
Member: 176999
Thanks Meter: 32
Welcome to Octopus Box Samsung software version 1.9.4
steps:
9. Restart phone.
Mode: Normal
Creating NVM backup
Reading NVM done!
Repairing NVM for SHV-E160S phone...
NVM repair completed successfully
Please, restart the phone to apply changes
_ROOTED.oct
PC.
following steps:
Found phone on
Mode: Normal
Unlocking phone...
still unlocking failed .... any soutions?? help
Old 08-15-2013, 15:07   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
No need to make Unlock, insert SIM card and check whether your phone is unlocked.
Old 08-15-2013, 15:16   #5 (permalink)
alfin5557's Avatar
Member: 176999
Thanks Meter: 32
still locked no signal / no service mode if insert sim card
Old 08-15-2013, 16:27   #6 (permalink)
Member: 1146942
Sonork: 100.1587278
What phone "say" when You insert SIM card? What code does your phone request exactly?
Old 08-15-2013, 20:39   #7 (permalink)
alfin5557's Avatar
Member: 176999
Thanks Meter: 32
when entering phone sim card does not show up code only visible posts and no service signal does not appear, already in re flash using the existing firmware in support area still lock, repair NVM also still lock, unlock every in using octopus software samsung phone always unlocked failed, is there a solution? thx
Old 08-16-2013, 06:25   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
Sorry, hard to say where can be the problem without having this phone in our hands... Try to use another SIM/USIM cards and say the result here...
Old 08-16-2013, 07:05   #9 (permalink)
alfin5557's Avatar
Member: 176999
Thanks Meter: 32
try another sim card same no service, phone still locked... I think this problem phone not unlocked by software, any solutions for other problem?? thx for respons
regard,
alfindo
Old 08-16-2013, 07:40   #10 (permalink)
Member: 1146942
Sonork: 100.1587278
Try to make Repair EFS, then re-flash and make Repair NVM.
Old 08-16-2013, 20:19   #11 (permalink)
alfin5557's Avatar
Member: 176999
Thanks Meter: 32
I have try to make repair EFS, then reflash and make Repair NVM but IMEI 0000000000000
I can't fix IMEI use octopus samsung software cause progrese not done, just runing long time, any solutions ?thx
Old 08-19-2013, 08:26   #12 (permalink)
Member: 1146942
Sonork: 100.1587278
post here full software log and describe all the actions You perform step by step.
Also say whether your phone is unlocked now?
Old 08-22-2013, 00:32   #13 (permalink)
alfin5557's Avatar
Member: 176999
Thanks Meter: 32
this screenshot and log file for progres fix IMEI
Old 08-22-2013, 09:46   #14 (permalink)
Member: 1146942
Sonork: 100.1587278
Please install the latest Software version and perform all the steps from software manual how to make Repair IMEI, then post here full software log with all of your actions.
Old 08-25-2013, 21:33   #15 (permalink)
alfin5557's Avatar
Member: 176999
Thanks Meter: 32
Problem solved ,thx for helpfully from Octopus team
Page generated in 0.20378 seconds with 9 queries
