08-15-2013, 13:30 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: R474 5VS
Member: 176999 Status: Offline Thanks Meter: 32 | Unlocking SHV-E160s problem [Solved] this log for progress : Welcome to Octoplus/Octopus Box Samsung software version 1.2.4 ----------------------------------------------------------------------------------- To connect SHV-E160S phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "996412" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#9090#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. Selected firmware file: E160S.UH24.1912_CL966809_REV02 _ROOTED.oct <<<<< this file from supprot area Please switch your phone to the download mode and connect it to a PC. To put SHV-E160S phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing MDM section... MDM section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM34 Selected model: SHV-E160S Mode: Normal Phone model: SHV-E160S Firmware compiled date: May 03 2012 Firmware compiled time: 10:00:00 Firmware released date: Jul 31 2012 Firmware released time: 13:16:06 Phone IMEI: 359795-04-237570-1 SW Version: M9200B-SCAQCSZD-3.4.706025 Unlocking phone... Phone unlocking failed help for solution my problem,thx for respons Last edited by Octopus box; 08-26-2013 at 08:24. |
08-15-2013, 14:58 | #3 (permalink) |
Member: 176999 Status: Offline Thanks Meter: 32 | Welcome to Octopus Box Samsung software version 1.9.4 ----------------------------------------------------------------------------------- To connect SHV-E160S phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "996412" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#9090#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM34 Selected model: SHV-E160S Mode: Normal Phone model: SHV-E160S Firmware compiled date: May 03 2012 Firmware compiled time: 10:00:00 Firmware released date: Jul 31 2012 Firmware released time: 13:16:06 Phone IMEI: 359795-04-237570-1 SW Version: M9200B-SCAQCSZD-3.4.706025 Creating NVM backup Reading NVM done! Repairing NVM for SHV-E160S phone... NVM repair completed successfully Please, restart the phone to apply changes Selected firmware file: E160S.UH24.1912_CL966809_REV02 _ROOTED.oct Please switch your phone to the download mode and connect it to a PC. To put SHV-E160S phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing MDM section... MDM section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM34 Selected model: SHV-E160S Mode: Normal Phone model: SHV-E160S Firmware compiled date: May 03 2012 Firmware compiled time: 10:00:00 Firmware released date: Jul 31 2012 Firmware released time: 13:16:06 Phone IMEI: 359795-04-237570-1 SW Version: M9200B-SCAQCSZD-3.4.706025 Unlocking phone... Phone unlocking failed still unlocking failed .... any soutions?? help |
08-15-2013, 20:39 | #7 (permalink) |
Member: 176999 Status: Offline Thanks Meter: 32 | when entering phone sim card does not show up code only visible posts and no service signal does not appear, already in re flash using the existing firmware in support area still lock, repair NVM also still lock, unlock every in using octopus software samsung phone always unlocked failed, is there a solution? thx |
08-16-2013, 06:25 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Sorry, hard to say where can be the problem without having this phone in our hands... Try to use another SIM/USIM cards and say the result here... |
08-16-2013, 07:05 | #9 (permalink) |
Member: 176999 Status: Offline Thanks Meter: 32 | try another sim card same no service, phone still locked... I think this problem phone not unlocked by software, any solutions for other problem?? thx for respons regard, alfindo |
08-16-2013, 20:19 | #11 (permalink) |
Member: 176999 Status: Offline Thanks Meter: 32 | I have try to make repair EFS, then reflash and make Repair NVM but IMEI 0000000000000 I can't fix IMEI use octopus samsung software cause progrese not done, just runing long time, any solutions ?thx |
08-19-2013, 08:26 | #12 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
Also say whether your phone is unlocked now? | |
08-22-2013, 09:46 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please install the latest Software version and perform all the steps from software manual how to make Repair IMEI, then post here full software log with all of your actions. |
