06-24-2015, 01:18 | #63 (permalink) |
Freak Poster Join Date: Jun 2015 Location: Texas
Member: 2407948 Status: Offline Thanks Meter: 23 | N910V After #*9090# I accidentally hit option 1 instead of USB which I believe was option 2. The phone now boots up but restarts itself every 15 seconds or so. Guidance? |
06-24-2015, 01:20 | #64 (permalink) |
Member: 2407948 Status: Offline Thanks Meter: 23 | N910V In #*9090# I hit option 1 rather than usb which I believe is option 2. Phone started rebooting every 15 seconds on its own and I cannot do anything. Guidance? |
06-30-2015, 21:16 | #68 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | You don't need QCN for Verizon variant you might of done something wrong ... but if you still need it here it is ... http://www.mediafire.com/download/lm...d/SM-N910V.qcn |
07-06-2015, 02:01 | #70 (permalink) |
Member: 2407948 Status: Offline Thanks Meter: 23 | Power phone down then plug in your RJ45 connect to octoplus and it should boot up automatically. Then *#0808# will work. |
The Following User Says Thank You to theharddrive For This Useful Post: |
07-16-2015, 22:11 | #71 (permalink) | |
Major Poster Join Date: Nov 2014
Member: 2286905 Status: Offline Thanks Meter: 6 | Quote:
I have a N910V running 5.0.1 and I am unable to write certificate. Have done the above step and it does not work. Phone is not rooted have not tried to wipe EFS. Also, CP logging is enabled. Doing the above step I am able to enable DM + Modem +ADB But when I try to write certificate using octoplus I get error message "Write certificate fail" Any help will be greatly appreciated. Should I just down grade the android version? Thank you. | |
07-19-2015, 03:56 | #73 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 241855 Status: Offline Sonork: 1623913 Thanks Meter: 89 | Downgrade it to kitkat and write cert with z3x or octopus box after match imei as same as mied Sent from my iPhone using Tapatalk |
The Following User Says Thank You to olubolajames For This Useful Post: |
