02-10-2015, 22:46 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2335578 Status: Offline Thanks Meter: 105 | Verizon Note 4 N910V cert write sucessful ----------------------------------------------------------------------------------- To connect SM-N910T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N910V phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-N910V Reading info... Mode: Normal Firmware compiled date: Aug 27 2014 Firmware compiled time: 08:00:00 Firmware released date: Nov 4 2014 Firmware released time: 01:58:58 SW Version: MPSS.DI.3.0.c5-00228-M9625TAARANAZM-1 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! QCN read successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-N910V Selected file: C:\Users\SNOWBOARDKID503\Desktop\Cert_SM-N910T \xxxxxxxxxxxxxxx_N910T.cert Powered on perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM4 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes Last edited by Octopus box; 02-11-2015 at 08:01. |
The Following User Says Thank You to Isellcert For This Useful Post: |
02-12-2015, 20:14 | #9 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Nice. I didn't think anyone else knew how to "enable" the service menu on the Verizon Note 4 without root to wipe the EFS. It's quite easy |
The Following User Says Thank You to ecs87 For This Useful Post: |
02-12-2015, 20:46 | #14 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | Hell no. Their stupid lock persists even if the EFS is wiped. I know that there's IPC commands needed to be manipulated over RIL to unlock the international portion of it. The domestic portion I'd assume is the same, or is hard-programmed into the modem. |
