12-03-2014, 21:06 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: Worldwide
Member: 2174901 Status: Offline Sonork: 100.1671257 Thanks Meter: 1,248 | Sch-i535 imei *#06# not go to see my imei i flash with new firmware and same what the problem To connect SCH-I535 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#22745927" number. 7. In Hidden Menu select "enable" radio button. 8. Go to dial window. 9. Enter "*#7284#" number. 10. Set "UART" radio button to "PDA" value. 11. Go to "Qualcomm USB Settings". 12. Select "RNDIS+DM+MODEM". 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SCH-I535 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM4 Mode: Emergency Selected firmware file: I535VRUCML1_I535VZWCML1_HOME_4.3.oct Please put the phone into Download Mode and connect USB cable. To put SCH-I535 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing SBL2 section... SBL2 section has been written successfully. Writing SBL3 section... SBL3 section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SCH-I535 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM4 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SCH-I535 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM4 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SCH-I535 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM4 Mode: Emergency |
12-03-2014, 21:42 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Hello. Please make "Factory Reset", then carefully perform each following step: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#22745927" number. 7. In Hidden Menu select "enable" radio button. 8. Go to dial window. 9. Enter "*#7284#" number. 10. Set "UART" radio button to "PDA" value. 11. Go to "Qualcomm USB Settings". 12. Select "RNDIS+DM+MODEM". 13. Go to dial window. 14. Press "Read Info" in software. |
12-03-2014, 22:09 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | There is no other way to connect the phone. Please make Factory Reset, re-flash the phone again and try perform steps 1-14 again. Also look here: http://forum.gsmhosting.com/vbb/f684...olved-1879883/ http://forum.gsmhosting.com/vbb/f684...-done-1769144/ |
01-02-2015, 15:04 | #5 (permalink) |
Freak Poster Join Date: Feb 2014 Location: Peshawar Age: 35
Member: 2123463 Status: Offline Sonork: 100.1652545 Thanks Meter: 29 | hi sir I have the same phone (sch-i535) it was in 4.3 version i just updated it to 4.4.2 stockrom and now its charging goes backwards i-e from 35% to 34% and so on and finally goes turned off. Now i want to Downgrade it back and it cant be downgraded what can i do now i m so woried plz help me |
01-02-2015, 15:12 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Fully charge phone's battery by using external charger, make Factory data reset and, cache partition and try to write 4.4.2 firmware again. Try to find and write other 4.4.2 Android firmwares. |
